How Do I Fix THIS - Pics Included. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-05-2013, 06:30 AM   #1
How do I fix THIS - Pics included.
Hi there,
As you will see from the picture I have included, I've got a MAJOR hole in a drywall which needs repair as I intend to paint the room.
I know precisely nothing about DIY so, if the problem can be successfully repaired, please be gentle in your instruction to ensure I understand what is being said.
Shane1988 is offline   Reply With Quote
Old 08-05-2013, 07:55 AM   #2
PoleCat's Avatar
Rewards Points: 1,646
You will need a piece of 1/2" drywall that is larger than the hole. Cut it rectangular to cover all damaged area. Place it against wall over damage and pencil the outline of your repair panel onto the wall. Cut the wall to match your pencil mark. Use 1X2 strips of wood and 1 1/4 inch drywall screws to carefully attach a lip around the perimeter of your cut out. Place your repair panel in the hole and screw it to the lip. Tape & mud, sand & prime. You are ready for paint.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 08-05-2013, 09:11 AM   #3
Rewards Points: 13,300
http://www.bing.com/videos/search?q=...ideo&FORM=VDRE
Old 08-05-2013, 09:15 AM   #4
Rewards Points: 6,652
Looks like you are going to have to span at least a 32" long section, and about maybe 24 to 36 inches (need a yardstick next to that section, to show height. Just use a straight edge to cut as close of a clean line vertical and level to allow you to draw at least a straight line across, that you can cut away with a roto-zip or drywall knife.
Then just attach with drywall screws (1 1/2" is fine), tape, mud, sand, lay another coat of mud, finish sand, then prime & paint.
Old 08-05-2013, 09:42 AM   #5
Use paper not webbed tape!
ToolSeeker (08-05-2013)
Old 08-05-2013, 10:09 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,158
As noted above....
When doing repairs, the moment the hole is larger than a few inches...it's actually easier to go big. In other words, (IMOP), it's easier to patch a 24x36" section vs a 4x4" section...reason being that that 4x4 will show up more obvious whereas the larger section is easier to blend in the seams.
See if you can locate the stud...you can save some effort by cutting down the middle of the stud. That way you have some wood to screw the new piece of drywall to.
I won't comment on the paper vs web tape.....I'm developing my own opinions that might go contrary to popular advice.
ddawg16 is online now   Reply With Quote
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
gregzoll (08-05-2013), Willie T (08-05-2013)
Old 08-05-2013, 11:36 AM   #7
Thanks lads. With your explanations, coupled with the videos Joecaption provided, I've got some sense of what needs doing in order to repair the wall.
I'll put in step-by-step form to make sure I've got everything right before I go to work on it.
1) I sketch a large rectangular shaped-box using a pencil, before using a keyhole knife to cut the designed section from the wall.
2) Then I tidy up the area, ensuring it is a near-perfect rectangle-shaped hole in the wall.
3) I then check if the hole has stud - which I assume is solid surface behind the wall strong enough to support screws. Failing to find stud, I find the appropriate sized wood to cover the height of the hole, before screwing the wood to the left and right of my large rectangle-shaped void.
4) Having done all that, I slot the right sized sheet of drywall/plasterboard into the hole, before securing it in place using more drywall screws.
5) Then I apply fibre tape around the perimeter of the thing, before applying several layers of compound - or mud - to the wall using a large drywall knife.
6) Then I smoke a victory cigar.
Let me know if I'm correct with these steps - especailly the last one - before I proceed with the plan.
Cheers again lads.
The Following User Says Thank You to Shane1988 For This Useful Post:
Old 08-05-2013, 11:42 AM   #8
JOATMON
ddawg16's Avatar
Change step 6 to a cold beer....
The Following User Says Thank You to ddawg16 For This Useful Post:
Old 08-05-2013, 11:48 AM   #9
One beer will turn into several, then I will most probably waste my hard work by putting my foot through the wall in a drunken rage, and that's no good for anybody.
No, I'll stick with the cigar.
Old 08-05-2013, 06:29 PM   #10
PoleCat's Avatar
You will find it much easy and get far better results by cutting out your patch first then using it as a template for the wall cut out. This way the patch fits the hole el perfecto.
Old 08-05-2013, 06:34 PM   #11
PoleCat's Avatar
Tequila gets me riled up, beer makes me docile. A cigar on the other hand makes me philosophical.
Old 08-05-2013, 10:01 PM   #12
Rewards Points: 4,792
What polecat is saying is basically switch 1. and 4. You cut your new piece of drywall first. Then you trace that piece (it should be larger than your damaged area) and cut around the trace. This way, you get a perfect fit. Otherwise it would be too hard to guess at how to cut the hole.
jeffnc is offline   Reply With Quote
Old 08-06-2013, 08:27 AM   #13
Rewards Points: 137
"You will find it much easy and get far better results by cutting out your patch first then using it as a template for the wall cut out. This way the patch fits the hole el perfecto."
So simple but so brilliant. I am patching a hole and would not have thought of that until right after I cut the hole. Haha
Troy32 is offline   Reply With Quote
Old 08-06-2013, 11:23 AM   #14
For the record, this is a different hole.
I will not get the victory cigar out just yet because I haven't won, and it is NOT a perfect fit - but overall what it look like?
I get the feeling one of you will tell me I'm going to have to take it down and start afresh, but I can't do that after all that work so think of an alternative suggestion.
Old 08-06-2013, 01:16 PM   #15
Yep, take it down, and cut the patch square and fit in the hole. You should really have no more than a 1/8" gap around the edges. Now of course if you are really good, you can do like some of us have done.
That is cut the section larger than the hole, cut into the Gypsum and back paper only, so that the front paper is used in place of tape. You still have to only cut away enough, that you do not leave a huge gap in the patch, when you place it back into the hole.
Soldering copper pipe in tight location- Help Needed Pics included amodoko Plumbing 20 08-11-2012 05:14 PM
General Help with replacing shut off valve under kitchen sink- Pics included amodoko Plumbing 4 04-02-2012 05:34 PM
Help Identifying a problem with my brickwork (pics included) feroxide Building & Construction 9 04-03-2011 06:04 PM
Color suggestions for exterior of house (pics included) gordholio Painting 1 07-05-2009 09:04 AM
Repairing interior wall cavity with mold, what would you do? (Pics included) pendlebg General DIY Discussions 4 06-16-2009 04:40 PM
