How Do I Finish Drywall On My Stair Steps - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-05-2011, 07:28 PM   #1
how do i finish drywall on my stair steps
my drywaller did a really bad job on my basement stairs there are large gaps between the treads abd the bottom of the drywall, I guess he figured the carpet would cover it up, is that the right nway to finish drywall on stairs? Should I try to fill the gaps and tape them
elkhunter is offline   Reply With Quote
Old 09-05-2011, 07:31 PM   #2
Busy DIYer
picflight's Avatar
Rewards Points: 150
That might not be the right way, it seems the installer figured it will not be very visible and perhaps would be covered.
picflight is offline   Reply With Quote
Old 09-05-2011, 07:34 PM   #3
DIY staff
Rewards Points: 7,174
I'd need to see a picture---But the stair case should have had a skirt board to butt the drywall to ---or a gap wide enough to slip the drywall along side the steps.
Asking a drywall hanger to cut zigzags onto paper covered gypsum and expecting a tight joint is hoping for more than most can deliver.
Old 09-11-2011, 06:08 PM   #4
Drywall contractor
Rewards Points: 1,070
Mike's correct, the stairs should have a skirt board. Often they aren't put in until the basement is finished, which means before the drywall hangers get there, the step treads need to be pulled up and cut back an an inch (each side) to allow the rock to go down behind the treads. After the rock is hung, the treads need to be pulled again, the 3/4" skirt board installed, then the treads are cut to the proper length and re-installed. In new construction when the drywall is hung, there are just temporary treads (2 2"x4"'s per tread usually) that are cut back far enough for the drywall and the skirt board o the trim man doesn't have to pull the treads....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Drywall finish Jpeters1 Drywall & Plaster 2 08-19-2011 10:09 PM
Drywall between wall and steps jburchill Drywall & Plaster 0 07-19-2011 10:46 PM
Adding exterior drain with concrete steps in way steveel Building & Construction 5 09-10-2010 05:23 PM
HELP! Contractor returns in AM! Uneven shelf - how to fix during drywall finish?? MrBoost Drywall & Plaster 6 04-08-2010 02:18 PM
Wood Finish to Stair Rails propilot5000 Painting 1 01-09-2007 07:22 PM
