How Do I Drywall Over This? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-17-2017, 07:42 PM   #1
Rewards Points: 2
How do I drywall over this?
This is a sewer pipe fitting that I notched the drywall for. There isn't anything behind the drywall in the corner so it's a weak joint made worse by my notch. I'd like to just add a angled piece of drywall to patch this. Any thoughts? Thanks in advance.
Pennwoodworks is offline   Reply With Quote
Old 05-17-2017, 07:45 PM   #2
Rewards Points: 14,026
Re: How do I drywall over this?
Little late now, studs should have been built out so the rock would clear the pipe.
There is no great looking way to cover that up.
Old 05-17-2017, 08:05 PM   #3
Rewards Points: 2
Who ever installed the drywall originally around the sewer pipe just boxed it out. See photo. This made the usable storage space along this wall pretty useless. I wanted the box gone so the wall would be continuous.
Old 05-17-2017, 09:10 PM   #4
Rewards Points: 734
Make a couple of 2x4 blocks with angle cuts. Then drywall over. Here's a crappy picture to give you an idea of what it looks like after drywall.
Upper left corner.
BIG Johnson is offline   Reply With Quote
Old 05-19-2017, 11:23 AM   #5
Rewards Points: 2
at this point you only have two choices, box it out, or fur the wall out to clear the pipe, just an idea, build a soffit all the way across and put some lights in it so that you don't have just a small box in the middle of the wall, depends on how fancy and how much you want to spend
ktmrider is offline   Reply With Quote
Sagging Joists & Strongback Question PSUlion01 Building & Construction 29 08-09-2015 02:12 PM
do you have to tape joints? begal Drywall & Plaster 34 08-09-2015 08:42 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 08:15 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
