Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 10-05-2008, 10:31 AM   #1
yummy mummy's Avatar
How do I correct small rips on my drywall?
Some areas of my drywall have little nicks on them and the paper has lifted.
What would be the best way to fix this?
Should I make an indent where the paper has ripped and fill it?
Should I just go over it with some compound?
Thanks for your help
yummy mummy is offline   Reply With Quote
Old 10-05-2008, 10:41 AM   #2
Take a utility knife and carefully cut the paper that is pulling up so that it doesn't pull any more. Then get some spackle and carefully fill the hole without going outside more than needed. Try to match the surrounding texture if you can.
Then paint over the patch.
If you need some texture you can get a spray can (it smells bad and is expensive) that will make all different kinds of texture. Practice on some scrap sheetrock or wood before try it for real.
Marvin Gardens is offline   Reply With Quote
Old 10-05-2008, 10:41 AM   #3
Drywall contractor
If they're just minor "dings" you can just touch up with a couple of coats of regular compound and lightly sand. Cut the loose paper away. If they're fairly large and the core of the rock is visible, you will need to tape and finish. (Mesh or paper; use setting compound on first coat if you use mesh.) You can make a small indentation if needed to get the surface flat prior to mudding.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-06-2008, 01:14 AM   #4
Thanks for all your help.
They are small rips. No drywall showing through. I will just remove the tape and put some compound on it. I think that will work.
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
Plaster on drywall? bofusmosby Carpentry 7 03-06-2008 08:30 AM
small holes in drywall mud kimmyb General Discussion 5 01-26-2008 10:21 AM
