How To Cut Bullnose Bead - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 06:01 PM   #1
How to cut bullnose bead
Just wondering how to cut bullnose bead in a finished looked at the 90 when meeting at the corners.
WorkMachine is offline   Reply With Quote
Old 11-29-2010, 08:25 PM   #2
The easiest way is to get pre-made corner caps. I've seen them at the big box stores, they're small plastic pieces you install before the corner bead. You can also get bullnose to square-edge transitions for the bottom edge, so you don't have to round the baseboard. Just Google "Bullnose corner caps" and you'll see what I'm talking about.
Mthrboard is offline   Reply With Quote
J Bead?? Or traditional 90 degree corner bead ryan5068 Drywall & Plaster 2 05-14-2010 11:18 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 10:28 AM
How to mitre bullnose corner bead?? Arbs Building & Construction 3 01-28-2008 01:32 PM
Mounting corner Bead KUIPORNG Remodeling 7 01-04-2007 09:20 AM
