How to create a cove transition between ceiling and wall?
I am renovating my entire house, gut job, the drywall is easily my least favorite part. Anyway, in the greatroom I have a cathedral ceiling with exposed beams. There is one wall that I did not remove and replace with new drywall, and the transition between the wall and ceiling between each beam is not even. Some edges are higher than others, some are skewed, it will look terrible if I just do normal corner bead. I am thinking that my best option is to create a curved transition, allowing me to somewhat even up the edges between each beam. How would I go about this? The inside bullnose is not going to be big enough, and I know I can't just start forming a curve with mud as it will need a large enough amount that it will just crack and eventually fall out. I would greatly appreciate any advice! Thanks very much.
