How Covered Should The Joint Be - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-12-2012, 11:11 PM   #1
Rewards Points: 278
How covered should the joint be
Butt Joint (got flooded-cut lower 24").
The joint is nice and feathered. It's a combo of durabond on the base, and AP for the 2/3d. In sanding, I may have sanded it a bit too tight....it's nice and flat. I plan to just run another thin coat just to cover the tape.
How much of the tape should be hidden. Totally invisible when sanded down ? Part of the grey is tape, and part of it is just how durabond looks when dried.
mobiledynamics is offline   Reply With Quote
Old 04-12-2012, 11:46 PM   #2
Rewards Points: 256
you want all the tape covered if possible .
oldrivers is offline   Reply With Quote
Old 04-15-2012, 11:18 AM   #3
Drywall contractor
Rewards Points: 1,070
It's the edges that really need to be covered so they don't show. Ideally, all of the tape would be covered with compound, but if some of it shows after sanding it is a "paintable" surface and should not show as long as the joint is smooth and level....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-16-2012, 12:12 AM   #4
Registered User
Rewards Points: 4,924
http://literature.usg.com/pdf/J510.pdf
Gary
Old 04-16-2012, 02:25 PM   #5
Rewards Points: 1,426
Generally if you can't feel it, you won't see it after painting. Is the tape fuzzy or just exposed?
mikegp is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
CBU Joint Issue? cobrakai Kitchen & Bath Remodeling 1 01-19-2011 10:11 PM
PVC Sprinkler Leak at T Joint D2D2 Landscaping & Lawn Care 3 08-26-2010 04:57 PM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 11:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
