How Close To Then End Must There Be A Stud? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-21-2013, 08:14 PM   #1
Rewards Points: 992
How close to then end must there be a stud?
I did an absolutely terrible job of framing, and am trying to cope with that.
I have a 15' wall. I can use the panels horizontally and cut them all to 7.5'. Then everything will fall nicely on studs, but I will have to cut 4 panels.
Alternately I can run one 8'. It will be on studs at each end. If I cut the other panel to 7' it will start on a stud and stick 3.5" over a stud at the end. Is that okay? (I am sure I had a good reason to have two studs 5" apart, but can't remember what it was). I could put a few pieces between the two studs to better support the 7' panel if that is necessary/helpful.
Or, I could just add a stud so the 7' panel ends on a stud, but that seems excessive.
I did a 13' wall today; only needed to add one stud.
But next time I will be experienced!
Toller is offline   Reply With Quote
Old 02-23-2013, 02:12 PM   #2
Rewards Points: 512
im kind of lost as to what your talking about.
so you have a 15' wall and yes your going to have to use 4 pieces.
buy 3 10' sheets. do the full 10' then half of another one.
then do the same on the bottom but stagger your joint.
princelake is offline   Reply With Quote
Old 02-23-2013, 05:29 PM   #3
retired union carpenter
Send a message via Yahoo to coupe
could the studs 5" apart be for intersecting wall nailers?
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 02-23-2013, 05:50 PM   #4
Rewards Points: 14,312
http://www.bing.com/images/search?q=...electedIndex=3
Not sure where your going to find these 10' panels any lumber yard or box store is going to have 10's or 12's.
Old 02-23-2013, 07:16 PM   #5
Davejss's Avatar
Rewards Points: 782
If you don't want to add a stud, which seems like the best choice to me, you could add a few pieces of horizontal blocking in the last stud bay. But from here it seems as though just adding a stud would be the way to go.
Davejss is offline   Reply With Quote
Old 02-23-2013, 08:15 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 2,128
I guess you learned the importance of the number 16.
Don't feel bad....
Ever hear the phrase "You learn by your mistakes"......well, how do you think all the guys in here got so bloody smart?
With few exceptions, you almost always end up cutting one or more panels.
BTW...I assume your talking about drywall panels?
ddawg16 is online now   Reply With Quote
Old 02-24-2013, 05:37 AM   #7
Rewards Points: 194
I've opened up more than one wall in my house and have had this exact thought.
I would just add a stud to make it work.
Larryh86GT is offline   Reply With Quote
Steel Stud Device Box Installation tjames Electrical 3 09-15-2011 11:30 AM
Tips needed to cut stud close to wall montpsycho Carpentry 14 01-11-2011 08:03 PM
remodel recessed housing proximity to stud DIYGST Electrical 5 01-02-2010 03:40 AM
Studs too close together for structured wiring panel juengl4 Building & Construction 15 12-25-2009 09:52 AM
Please, help with sheathing and stud placement Mrmusic Building & Construction 2 09-10-2008 04:52 PM
