How Can I Hang Drywall Level On My Settled Ceiling Joists? - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-08-2012, 12:05 AM   #16
Rewards Points: 12,808
Use brick string not monofliment.
Brick string will not strech.
Old 02-13-2012, 08:33 PM   #17
Find a permiter level line. Cut long tapered full length shims and attach them to the bottom of the individual floor joists with floor glue and a mechanical fastener. Nails screws or staples depending on length needed. Drywall the ceiling.
masterofall is offline   Reply With Quote
Old 02-13-2012, 10:19 PM   #18
Rewards Points: 530
Could rewiring be avoided by using 1x furrowing perpindicular to the joists after they are leveled by one of the methods mentioned?
Btw, I like the long shims angle if possible.
Old 02-13-2012, 10:58 PM   #19
Rewards Points: 582
yes iam serious that is a good idea makes sense go for it ....
Old 02-13-2012, 11:04 PM   #20
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,284
I just went through this. I attach strapping perpendicularly to the bottom of the joists and shimmed each one until it's true. Start at the lowest point and work out from there. Once you have three pieces of strapping in place, the rest fall into place easily.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 02-14-2012, 10:02 AM   #21
011010100110111101100101
Rewards Points: 160
This is the first thing that came to my mind as well. Strap it, shim it level and flat.
It's easier to screw drywall on 1x3 furring strips than joist ends, especially if your spacing is a hair off. You have more edge to work with.
-- Joe
anesthes is offline   Reply With Quote
Old 06-04-2012, 12:50 AM   #22
Lavid2002's Avatar
Rewards Points: 85
I finished the job almost! All that is left is crown molding and drywall in between the joists I laid up there. This is my first carpentry job ever aside from 3 amateur workbenches made from 4x4s and 2x4s. I am pretty stoked with the result. Here are a few pix
Thanks for the help everyone!!!
By the way, the joists just LOOKED uneven because the wall the contractor built behind it wasn't even! Lol! It was an optical illusion. The floor was also marginally uneven accounting for the elevation differences.
-Dave
Lavid2002 is offline   Reply With Quote
Old 06-04-2012, 08:58 AM   #23
I'm confused, why was the sheetrock not put up first then the coffering installed over it?
Now there's going to be air gaps and one pain in the butt drywallljob.
When we do a job like this we install the drywall, finish it and prime and paint, then install ripped 2 X 6's that get screwed to the ceiling joist in the pattern needed, this gives you something to attach the boxing to from the sides. The wood used for the boxing gets finished before installing so your not dealing with getting anything on the new ceilings.
Also why is there what looks like a piece of drip cap nailed to the beam?
Old 06-04-2012, 10:08 AM   #24
Rewards Points: 140
ditto .......
Fix'n it is offline   Reply With Quote
Old 06-04-2012, 10:36 AM   #25
Lavid2002's Avatar
Rewards Points: 85
The ceiling is very low and every inch counts, so I found a way to hand drywall without even needing to mmud anything except screw holes. I put 2x4s up and then boxed them out. Now I will simply cut drywall pieces to fit and screw them up to the joists.
As for the gap in between the drywall and the boxes that will be hard to mud?.. No mudding needed, if I cut the drywall right I will have 3/4" of relief that they crown molding will cover up. So I will simply slap the drywall up then pop the crown molding up.
I am not very good at taping, so I found a way to make the ceiling a little higher, ad avoid taping the ceiling. I think it is a great idea
Does that make sense?
I don't understand this. Can you please elaborate?
Old 06-04-2012, 11:25 AM   #26
Rewards Points: 140
my basement ceiling is 6'4". so i know what you mean about "every inch counts". but i think you made a lot of extra work for yourself, just to gain 1/2".
but, good luck with your project. and report back with the results.
Old 06-04-2012, 12:35 PM   #27
Lavid2002's Avatar
Rewards Points: 85
Really? I think I saved myself some time
-No spackling or taping
-No hunting for joists when I screwed in the 2x4s to the joists to hang the blocks for the coffered ceiling
-Now I can hand drywall easily by myself instead of working with two people to hand 4x8 sheets.
Are there any downsides I missed? The job seems pretty strait forward, the only downside being the degree of accuracy needed for my drywall cuts.
-Dave
Old 06-14-2012, 10:41 PM   #28
hboogz's Avatar
Rewards Points: 97
count me in for being interested in seeing pics of the finished project. looks good so far, but I'm far from the expert.
Harry.
hboogz is offline   Reply With Quote
Old 06-14-2012, 11:44 PM   #29
Lavid2002's Avatar
Rewards Points: 85
Alright :D Here's an update so far! Drywall is hung, spackled, primed, and painted in between the beams. Thanks everyone! I am very near completion.
-Dave
Old 06-15-2012, 12:11 AM   #30
Registered User
Rewards Points: 4,912
Did you have this inspected yet, or get a permit to finish the basement? Just a few concerns I'm seeing from your pictures.....
Gary
hanging ceiling drywall in a basement charlie bob Drywall & Plaster 5 06-21-2013 12:30 PM
How do I level a ceiling? Drywalling my ceiling Tom_123 Building & Construction 6 05-18-2011 12:17 AM
How to best level uneven ceiling joists? luvdairish Building & Construction 1 09-20-2010 12:17 AM
garage ceiling joists josh123 Carpentry 6 07-15-2009 12:07 AM
Spacing of ceiling joists Pineconeman Building & Construction 3 05-14-2005 12:16 AM
