How Can I Get Away Without Floating This Patch. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-10-2012, 04:29 PM   #1
Rewards Points: 288
How can I get away without floating this patch.
I had to cut a 9" square to get access to plumbing..
Double 1/2 wall.
Dare I put the 1st layer of rock on, bevel the corners on the 2nd layer just mud the seam (no paper & or no Fibafuse). I'm avoiding the massive feather I need to do if I create a "thickness" due to paper. It's close to a baseboard that is snug....so feathering on one end will look sorta ~eh~ as I will just feather out around the edge of the baseboard.
Thoughts, suggestions.
mobiledynamics is offline   Reply With Quote
Old 06-10-2012, 04:40 PM   #2
DIY staff
Rewards Points: 7,174
Never seen that work----if it doesn't work for you--now the paper will be going over even more thickness---your call---
Old 06-11-2012, 12:05 PM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
The seams are probably going to crack just from expansion and contraction.
Potential buyer of my house withdrew interest-no bsmt floating walls gjw Carpentry 1 11-08-2010 11:37 AM
EPDM Roof Patch antelope420 Roofing/Siding 1 05-11-2010 08:20 PM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 11:16 AM
Floor patch HomeDepot23 Flooring 2 07-24-2008 06:03 AM
