-   -   How can I get away without floating this patch. (http://www.diychatroom.com/f101/how-can-i-get-away-without-floating-patch-146642/)
mobiledynamics 06-10-2012 05:29 PM
I had to cut a 9" square to get access to plumbing..
Double 1/2 wall.
Dare I put the 1st layer of rock on, bevel the corners on the 2nd layer just mud the seam (no paper & or no Fibafuse). I'm avoiding the massive feather I need to do if I create a "thickness" due to paper. It's close to a baseboard that is snug....so feathering on one end will look sorta ~eh~ as I will just feather out around the edge of the baseboard.
Thoughts, suggestions.
oh'mike 06-10-2012 05:40 PM
Never seen that work----if it doesn't work for you--now the paper will be going over even more thickness---your call---
Maintenance 6 06-11-2012 01:05 PM
The seams are probably going to crack just from expansion and contraction.
