How to blend in the ceiling gap after wall removal
I removed two walls during the bathroom remodel and replaced the ~5" gap with drywall strips then filled with joint compound, I'll need to fill in more to level with the surrounding ceiling ... is this a good way to do it?
What's the best way (new 1/4" drywall on ceiling?)?
How should I fill the gap between new drywall/ceiling?
How should I match texture on the ceiling (Is that popcorn?)
Thank you.
A picture is worth a thousand words. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
