Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 08-21-2012, 07:27 PM   #1
How to best fix my texture mess up?
Working on finishing new drywall in a room addition. The texture is "Sante Fe" style. I've done some texture before but not this style so I'm learning as I go.
I finally achieved the general look I was after but I felt my new texture had a "busier" pattern than the rest of the room so I tried to smooth some areas out to make it less busy. Wishing I hadn't done that because now I've got a wall that looks lumpy. I probably could have fixed it by sanding down the lumps until everything was smooth but I didn't notice the problem until after priming the walls.
So now I'm not sure what to do...should sand down the lumpy areas even though they're primer'd or should I attempt to skim coat the wall to even it out and redo the texture where necessary? It's really just one wall...about a 10x10 area...
QuickStudy is offline   Reply With Quote
Old 08-29-2012, 04:15 PM   #2
Drywall contractor
No clue what "Santa Fe" style is. Textures are called different names in different areas too. I may not be able to help, but a picture would surely help and someone else may recognize it....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Tags
drywall, sante fe, texture
Help with texture - any opinions on SW Faux Impressions products Sangiovese Painting 0 10-08-2011 09:10 AM
primer not adhering to drywall texture? eli_carson Drywall & Plaster 10 08-18-2009 02:46 PM
How to achieve this stucco texture? --pix inside... Kooter Building & Construction 2 08-26-2008 07:24 AM
Smoothing out skip troweled wall texture wem Remodeling 2 03-03-2008 12:57 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 04:38 PM
