House Wall Between House And Garage - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-15-2010, 11:48 AM   #1
Rewards Points: 640
House wall between house and garage
I am about to put drywall back up on what would be an "Exterior" wall of the house be our garage is attached... it had 1/2" standard drywall but we ripped it out to insulate the wall (none at all in there)... well going to buy the new drywall tonight to start the job... is there any code requirement for this now days for a wall that is between the garage and a house? right now its drywalled on the inside the house side with 1/2" drywall... then the wall is frammed out in 2x6's I put r-19 faced insulation (faced part facing the inside of the house since the garage is unheated) so can I just do what the builders did and redo it with 1/2" or do I need to double up here and make it a full inch with seams overlapped by the second layer or put some type of fire resistant drywall (I dont think anyone sells that in our area... its a special order product at the least)
I want to do this right since its being redone to start with...
BlueBSH is offline   Reply With Quote
Old 06-15-2010, 12:03 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
In many areas, 5/8 drywall on the garage side is acceptable between a garage and living area. - Pay attention to any holes and penetrations
concretemasonry is offline   Reply With Quote
Old 06-15-2010, 07:18 PM   #3
firehawkmph's Avatar
Rewards Points: 1,824
Also should be type 'X', should say so right on it, refers to the fire rated drywall vs. regular drywall.
Mike Hawkins
firehawkmph is online now   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
oh'mike (06-15-2010)
Old 06-19-2010, 10:13 AM   #4
Drywall contractor
Rewards Points: 1,070
Check your local building code. If 1/2" is acceptable, use it. Won't affect your door jamb width. Some counties in this area require 5/8" on the common wall of a garage (and ceiling if it's a drive-under), some don't. Some only require it if the hot water heater or furnace is in the garage (pilot light and gas fumes possibly mixing).
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 10:07 AM
Attaching garage to house eric haley General DIY Discussions 5 02-26-2009 08:38 AM
Adding on to house to build a garage. Ohioguy Building & Construction 5 02-09-2008 05:44 AM
Frost Build Up On Interior Garage Wall richw Building & Construction 8 01-06-2008 10:47 AM
Replacing Wall in Garage viking1974 Building & Construction 3 08-10-2007 11:23 PM
