Hot Mud, Finishing & Batch Workability - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-14-2013, 09:25 PM   #1
Hot mud, finishing & batch workability
I have been mixing only a mud pans worth at a time due to fear of it setting in a bucket, if you mix a buckets worth of synko pro set 90 how long will it be workable, will the bucket allow for it to stay wet longer?
Also is it ok for me to use this for ALL my coats (mesh tape)
Thanks!
http://www.homedepot.ca/product/synk...-kg-bag/911228
wingzjr is offline   Reply With Quote
Old 10-14-2013, 10:49 PM   #2
DIY staff
Rewards Points: 7,174
It will set a bit faster in the bucket than the 90 minutes---However, I would mix a larger batch if you can use it all within an hour or so---
Why would you use that for all coats? It's rather difficult to sand---that is why most people use topping compound for the final coat.
Also, Why mesh and not paper? I have the best results with paper--I haven;t used mesh in 15 or 20 years----
Old 10-14-2013, 11:09 PM   #3
Renovating My Land Yacht
Rewards Points: 616
I had to mix up a bigger batch to fill in a wacky corner prior to taping and used a bucket. One tip - keep the bucket sides clean as you use it as in VERY clean...those fiddly buggers that get left on the side set quicker much quicker than the main portion. This happened to regular mud as well but with the hot mud its mucho quicker.
forcedreno2012 is offline   Reply With Quote
Old 10-15-2013, 01:12 AM   #4
for but joints you only really have one coat right? you just taper out farther and farther correct?
how would you use hot mud + topping compound in that situation?
Old 10-15-2013, 04:35 AM   #5
DIY staff
I set paper tape with multipurpose---this is also called setting compound --it contains glue and is rather hard to sand.
Next coat--either hot mud or multipurpose---
Final coat---light weight----
I don't use mesh---perhaps a mesh user will chime in---Where is Pollecat?
Old 10-15-2013, 06:54 AM   #6
PoleCat's Avatar
Rewards Points: 1,646
I swore off the mesh. Used it for years on partitions at work with no issues but found out the hard way at home that it hairline cracks on a ceiling. I am now hard core paper man.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 10-15-2013, 07:29 AM   #7
747
registered
747's Avatar
Rewards Points: 534
I don't understand why your using hot mud? Most guys only use this doing quick patching here and there.
747 is offline   Reply With Quote
The Following User Says Thank You to 747 For This Useful Post:
oh'mike (10-15-2013)
Old 10-15-2013, 09:10 AM   #8
Rewards Points: 5,974
ABSOLUTELY NOT a mesh tape guy but hot mud is primarily used for fill and by some for first coat. It doesn't matter if its in a bucket or on a wall hot mud sets by a chemical reaction not exposure to air that is why sometimes it's set and still looks wet and you can put another coat on top. And no one coat is not enough you need 3 coats tapering each one out farther. The reason you usually only use one coat of hot mud is it's hard to work with, it's hard to sand, it flashes paint really bad. And then there's mesh tape, no I'm not even going to go there.
finishing a basement? what, me worry? itsnotrequired Project Showcase 36 09-18-2012 07:00 PM
Exterior Finishing of a New Constr. Window Install (siding etc.) DefyInertia Windows and Doors 3 04-11-2012 12:29 AM
Length of finishing nail for baseboards djgrant Carpentry 6 06-06-2011 09:01 PM
Normal level of finishing new drywall? MikeKy55 Drywall & Plaster 23 05-21-2011 04:42 PM
Finishing nail removal bklauer Carpentry 6 09-05-2006 08:13 AM
