Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-05-2011, 11:17 PM   #1
Horizontal Studs
Quick question. Normally I have worked on vertical studs or horizontal furrings that a 4x8 would cover.
I am working on a larger room with horizontal furrings with vertical furrings every so often. With horizontal furrings do you still need to end on vertical furring?
jburchill is offline   Reply With Quote
Old 07-06-2011, 01:06 PM   #2
Drywall contractor
Horizontal Studs
A picture would help, but if you're hanging the board horizontally and the vertical furring runs from floor to ceiling, definitely break the butt joint on the vertical. Your butts should be nailed/screwed every 8" or so and I assume the horizontal furring is on 16" centers???
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Making wall studs plumb and on plane laxgrandma Carpentry 1 07-06-2011 06:32 PM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
How to repair rotted joists and studs? Snav Building & Construction 5 02-24-2010 11:35 PM
framing conundrum: 2" PVC vent pipe going horizontal through 2x4 studs amakarevic Building & Construction 18 01-19-2008 07:47 PM
piece of horizontal wood through studs? yummy mummy Remodeling 13 11-24-2006 08:33 AM
