-   -   Horizontal Studs (http://www.diychatroom.com/f101/horizontal-studs-109794/)
jburchill 07-05-2011 10:17 PM
Horizontal Studs
11 Attachment(s)
Quick question. Normally I have worked on vertical studs or horizontal furrings that a 4x8 would cover.
I am working on a larger room with horizontal furrings with vertical furrings every so often. With horizontal furrings do you still need to end on vertical furring?
bjbatlanta 07-06-2011 12:06 PM
A picture would help, but if you're hanging the board horizontally and the vertical furring runs from floor to ceiling, definitely break the butt joint on the vertical. Your butts should be nailed/screwed every 8" or so and I assume the horizontal furring is on 16" centers???
