Home Owner - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-18-2013, 05:45 PM   #1
home owner
what is the best way to drywall a 9 foot ceiling. with limited drywall waste.
alanmorracco is offline   Reply With Quote
Old 02-18-2013, 06:00 PM   #2
Horizontal, go to a drywall supply house to purchase the width that is needed to go horizontal
dvatt is offline   Reply With Quote
Old 02-18-2013, 06:01 PM   #3
Rewards Points: 14,294
Order from a real drywall supply and get 10', or just use 12'.
Almost no differance in cost.
Old 02-18-2013, 06:02 PM   #4
DIY staff
Rewards Points: 7,174
Drywall is available in 4 1/2 foot wide sheets----that is the easiest way---you will need to contact a drywall supplier---but most areas have them---
If you are in an area that does not----stand up sheets can be done----or a 12" belly band ---or a 12" band at the floor---
How much 9 foot walls in your project?
Old 02-18-2013, 06:02 PM   #5
Rewards Points: 676
I believe "waste" is all a part of drywalling.
There are some here that would recommend getting 54" wide sheets and hanging them horizontally. If I were you I would buy 10' 48" wide sheets and hang them vertically.
How good are you at taping "butt" joints?
B
Beepster is offline   Reply With Quote
Old 02-18-2013, 07:03 PM   #6
Horizontal is the only way to hang drywall. So much less taping is needed
Old 02-25-2013, 08:14 PM   #7
Handyman
brucem609's Avatar
Rewards Points: 79
I don't understand why you say much less taping is involved if you lay the boards horizontal?
Either way you still have the butt joints to handle, and they are more difficult to do correctly!
Keep as many factory seams together as possible, keep the butt joints at the top and bottom and you don't have to deal with them!
brucem609 is offline   Reply With Quote
Old 02-25-2013, 08:20 PM   #8
You can lay horizontal and not have butt seams you just need long boards. If the room is that large on the long walls go vertical and short walls horizontal
Old 02-25-2013, 09:42 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 422
For some reason I thought he was doing a ceiling. A small room, maybe a bathroom.
Jaz
Old 02-26-2013, 05:39 AM   #10
Not so new
12penny's Avatar
Rewards Points: 520
Hanging vertical puts the entire 9' seam on one stud/joist. Much more likely to crack with changes of season.
12penny is offline   Reply With Quote
Old 02-26-2013, 09:23 AM   #11
Rewards Points: 6,034
To hang vertical you are with 1 1/2" studs for 2 pieces of drywall if you don't get them centered on the stud 1 of them doesn't have enough room for the screws on the next sheet to bite. To hang vertical you now have ????? number of seams to finish. To hang horizontal with 54" you have one seam down the center and it is a factory seam. if your wall is longer than 12' end the drywall between the studs and use these http://trim-texestore.com/index.php?...t_detail&p=234 and eliminate butt joints.If you go the belly band route remember you will have 2 continuous butt joints all the way around the room. and if your walls are 1/2" drywall your belly band should be 3/8".
Old 02-27-2013, 05:43 PM   #12
Rewards Points: 4,796
Some of the replies in this thread make no sense.
There are different reasons for hanging drywall vertically or horizontally. But eliminating butt joints is not a reason to hang horizontally. 9' drywall hung vertically in a 9' room basically eliminates butt joints. You can also eliminate them by using drywall that's longer than the longest wall in your room and hanging horizontally. But depending on the size of your room, this can get very difficult for 1 and sometimes even 2 people to handle.
jeffnc is offline   Reply With Quote
Soon to be home owner Atomic Teaspoon Introductions 2 05-27-2011 08:52 PM
New home owner - Main break box questions... liberty610 Electrical 8 12-07-2009 05:08 PM
First Time Home owner. typo Introductions 2 12-07-2009 10:04 AM
New and first time home owner and new to DIYchatroom Yoo Shin Introductions 4 10-14-2007 10:41 PM
