Is This Hole Fixable With Hot Mud? - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-26-2012, 10:40 AM   #16
Drywall contractor
Rewards Points: 1,070
There is a learning curve to using a Rotozip. Flat tape & finish....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 07-28-2012, 12:48 PM   #17
Rewards Points: 256
take a knife and bevel the edge , fill with hot mud use thicker , scrape and tape , then finish . easy repair. by the way the patch of hotmud and tape is stronger than the drywall itself. you just need to use a good 10-12 inch blade to feather it out. dont use a small blade like a 6 inch use 10-12 wide blade for the finish coat anyways.
oldrivers is offline   Reply With Quote
Repair Small Hole in Vinyl Siding Silkcityflorida General DIY Discussions 12 04-08-2013 03:34 PM
Cutting Hole for Bathroom exhaust jburchill Kitchen & Bath Remodeling 14 04-16-2012 11:55 AM
patching hole in 8" concrete block BlueBSH Building & Construction 5 08-09-2011 06:55 PM
Need to enlarge hole in wood top plate: or use flex with minimum OD. mysterylectric Electrical 3 08-09-2011 02:52 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 09:26 AM
