Is This Hole Fixable With Hot Mud? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-29-2012, 07:04 PM   #1
Rewards Points: 1,062
is this hole fixable with hot mud?
Is this hole, to the right of the light, fixable with hot mud? Or should i cut another sheet?
It is a 4" light. So the imperfection is maybe an inch.
Cutting holes in drywall, especially ceiling, is a friggin nightmare
Old 06-29-2012, 07:33 PM   #2
Rewards Points: 13,712
Should have be done with a hole saw or a Roto Zip with a pilot bit for a tight fit.
Good luck trying to patch that mess up.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
JetSwet (06-29-2012), Nailbags (07-14-2012)
Old 06-29-2012, 07:46 PM   #3
Rewards Points: 1,470
This would work:
http://www.homedepot.com/buy/paint-p...se-134952.html
If you can find them in lesser amounts...
ktkelly is offline   Reply With Quote
The Following User Says Thank You to ktkelly For This Useful Post:
amakarevic (06-29-2012)
Old 06-29-2012, 09:03 PM   #4
Rewards Points: 264
How much of it will the trim cover? If the trim covers all or most of the damage I would think you could mud it and it would look fine.
Those ring patches could come in handy, never seen those before.
7echo is offline   Reply With Quote
The Following 2 Users Say Thank You to 7echo For This Useful Post:
amakarevic (06-29-2012), Nailbags (07-14-2012)
Old 06-29-2012, 09:45 PM   #5
it was done with a Roto Zip.
but i make a mistake most of the time on the first try.
the way i do it is i get the rough X/Y coordinate where the center of the hole is and then make a pilot hole there and go in circles. the problem is when i get to the rim.
i tried the lipstick technique with varying degrees of success.
i just think that making ceiling patterns is the curse of this world. walls are easy cause i do it with roll paper, i spread it over the wall and then cut holes with scissors and then put some painting tape around perimeters cause i screw up those holes sometimes too. then i paste the stencil onto drywall and it works fine.
but the problem with the ceiling is that it is not easy to staple large sheets of paper onto it so i usually sacrifice one sheet to just make a stencil cause i make mistakes on the first draft 95% of the time.
i hate cutting drywall to measure, BTW. it is the ultimate curse for someone with A.D.D. everything else i have done in construction requires far less precision and is more forgiving to correct mistakes.
Old 06-30-2012, 04:21 AM   #6
DIY staff
Rewards Points: 7,174
Yes--Pack that---use 2 coats to pack it or it will sag.
I've had that happen when I forgot to lock the can to the bracket--hate it when that happens
Old 07-01-2012, 09:46 AM   #7
Rewards Points: 454
I would flat tape it,cause there is not anything for the mud to really stick to and might crack or fall out.
scottktmrider is offline   Reply With Quote
The Following User Says Thank You to scottktmrider For This Useful Post:
mae-ling (07-01-2012)
Old 07-01-2012, 10:10 AM   #8
Take the 4'' can out and get a 6'', if that is the only light in the room. Sounds, and looks like you should stay away from the rotozip, and chainsaws. A keyhole saw creates a lot less dust and is much easier to control. I'm not so sure about your stencil method, you should just be able to trace whatever shape you need right to the sheet rock and cut away. Just takes some practice, you'll get the hang of it. Good luck
CopperClad is offline   Reply With Quote
Old 07-01-2012, 11:33 AM   #9
Rewards Points: 454
Just tape it;looks like the rest of the ceiling is not taped.
Old 07-01-2012, 11:40 AM   #10
Rewards Points: 152
lol, that's pretty much the story of my life. Except I'll usually do it wrong the 2nd and 3rd time too
burnt03 is offline   Reply With Quote
Old 07-01-2012, 05:39 PM   #11
Rewards Points: 1,628
I would cut out a 10"x10" square around the hole. Cut a new 10"x10" drywall and recut the hole on it (you can do this over again if you make a mistake). Then insert two strips of 1x2s across the hole to the back of the drywall, screw to original drywall on each side, lay the new sheet over the can, screw to secure.
Just need to tape four straight seams.
miamicuse is offline   Reply With Quote
Old 07-01-2012, 09:00 PM   #12
retired union carpenter
Send a message via Yahoo to coupe
I agree with the above post#11, this hole should be cut using a drywall saw and a drywall circle cutter. even with ADD, simply measure each way from adjoining sheets , to center of light and mark on ceiling with light pencil.
rotozip works great, if you know how to use it? it looks like you ran yours in a clockwise rotation around the light? you should have measured 1/8" past edge of light and ran it counter clockwise, when running around boxes/lights,running inside= clockwise, running outside= counter clockwise.
good luck
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 07-06-2012, 08:06 PM   #13
I'd say that the hole is fixable with hot mud, and some tape. Cutting out a big hole around the light seems like a lot of work just to patch that hole, specially if its just going to get covered with texture. Hot mud with tape will do the same job, and its not like it going to just fall down. Just make sure your mud is thick. Come visit us for more
Last edited by Gary in WA; 08-02-2012 at 12:02 AM. Reason: removed advertising link per forum rules.
bluntman001 is offline   Reply With Quote
Old 07-06-2012, 08:45 PM   #14
Rewards Points: 454
I dont see what the big deal is.Looks like the rest of the room needs taping just put a piece of tape than fill and finish like normal.
If you cut the drywall short around the window do you move the window.
Old 07-13-2012, 09:39 PM   #15
flat tapem float it sand it, never know it is there. If your really worried float it out 10 inches, trim will cover after that.
bf514921 is offline   Reply With Quote
Repair Small Hole in Vinyl Siding Silkcityflorida General DIY Discussions 12 04-08-2013 03:34 PM
Cutting Hole for Bathroom exhaust jburchill Kitchen & Bath Remodeling 14 04-16-2012 11:55 AM
patching hole in 8" concrete block BlueBSH Building & Construction 5 08-09-2011 06:55 PM
Need to enlarge hole in wood top plate: or use flex with minimum OD. mysterylectric Electrical 3 08-09-2011 02:52 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 09:26 AM
