Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 11-28-2010, 04:53 PM   #1
Hiring drywall contractor for winter time work
Is it feasible to have a contractor do a job in the winter in rooms that are unheated and the day time temperatures are around 49 degrees in the day and as low as as 28 degrees at night?
francisfellow is offline   Reply With Quote
Old 11-28-2010, 05:00 PM   #2
Moderator
kwikfishron's Avatar
Any drywall contractors I know would bring their own heaters.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 11-29-2010, 07:20 PM   #3
i'll bring a heater but only use it while im there , its to much of a liability to supply a heater when your not there so i usually have the general contractor or homeowner responsible for the heater . and no that temperature is not good for taping . you want no less than 65 id say .... and if its a big job you want more than that just to be sure adeqite heat is coving the whole job ...
oldrivers is offline   Reply With Quote
Old 12-01-2010, 05:28 PM   #4
Thumbs up
That is a great question. In fact, it is good to see that you take such consideration in planning and hiring a contractor. What I would suggest is, if there is electrical power in the rooms or nearby is for you to personally place an electrical heater in the room. This will ensure that you have minimal fire hazards as well as supply heat to the rooms. Another factor when heating a room that is often overlooked is that when using heaters that operate off of propane you are actually adding additional moister to the air through the burning process of the fuel.
I hope you are able to work it out because I am sure you are excited to get in those rooms and start the finishing touches. Feel free to check out other sections on this site to get ideas, tips, and tricks on finish work.
Best of Luck,
MCH
MC Handyman is offline   Reply With Quote
Old 12-06-2010, 03:51 PM   #5
It would be pretty close to impossible to get the heat up to 65 and keep it that warm all day. May be I will have to wait until spring. Thanks for all the replies.
Old 12-06-2010, 03:55 PM   #6
you might not want to even hang the drywall in that temperature.
Old 12-15-2010, 11:56 AM   #7
Drywall contractor
MC is correct about the "torpedo" style heater adding moisture to the air. Even if you left them running to keep the temp above freezing, you risk having "delayed shrinkage" and your joints end up showing. Mud dries from the top down. It may appear to be dry and another coat is run. Then another. When all layers finally end up drying completely (which could literally take weeks) the ensuing "shrinkage" will make the joints visible, requiring further skimming. The recessed edge joints and outside corners will be the worst as they require the most mud to cover. Either get the furnace turned on or wait for better weather.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Drywall and Plaster Repair argana Building & Construction 8 09-15-2007 03:13 PM
Pay GC to construct home and finish it myself? L O N G . . . Badfish740 Off Topic 9 07-27-2007 09:44 AM
DIYers and Professionals Can Work Together. WilbUild Building & Construction 5 04-08-2007 02:43 PM
How is a drywall screwgun suppose to work? KUIPORNG Remodeling 10 11-03-2006 12:19 PM
