Hiding Butt Joints - Need Help - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-02-2010, 05:19 PM   #1
Rewards Points: 31
hiding butt joints - need help
I applied the mud on my butt joints and they are nice and smooth. But as always, there is a hump, the joints are about 8" wide now. I tried to hide it by putting compound on either side of the joint but when I drew my 8" knife, one end of the knife was at the peak of the hump and the other end was on the drywall, I could see a gap, I ended up removing all the mud. First I though it was the angle of my knife, about 45 degrees, but I noticed when I drew my knife slowly, the middle part bent/flexed and scraped the mud, the mud that I wanted to stay to fill the gap. I tried changing the angle to 90 but that caused washboard look. What am I doing wrong? Any tips?
kupalino is offline   Reply With Quote
Old 04-02-2010, 07:57 PM   #2
first thing is get a 12" good quality drywall knife, then just do one side of the seam and let dry then do the other side after it drys. you should finish up with a butt joint well over 24" wide so thar you are feathered out from the center line. with some gentle sanding and touch up your hump will feather out and be a thing of the past
The older I get the better I was
Old 04-02-2010, 08:23 PM   #3
Remodeling Contractor
now you see why a pro does not place butt joints on a stud. you use a tapered backer board which pulls the ends in and allows for a joint with no bulges.
The Following User Says Thank You to Bob Mariani For This Useful Post:
Willie T (04-02-2010)
Old 04-02-2010, 09:02 PM   #4
Registered User
Rewards Points: 526
Bob hit the nail on the head: http://www.taunton.com/finehomebuild...tt-joints.aspx
Be safe, Gary
Old 04-08-2010, 12:55 PM   #5
Rewards Points: 150
"Best" quality usually means some type of butt joint tool or product. Standard is just to feather it out the 24 inches like in the first response.
kgphoto is offline   Reply With Quote
Old 04-08-2010, 06:53 PM   #6
Drywall contractor
Rewards Points: 1,070
Products such as the "butt backer" isn't that commonly used. I've got "samples" sitting around I haven't used, but intend to some day. They cost several dollars apiece as I recall, so wouldn't be used by many pros in a whole house situation. Maybe a basement. They are a good concept....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 05-18-2010, 11:19 AM   #7
a 12" quality knife is a good too to use because it helps you feather out the joint compound smoothly.
You'll have to do it in several coats. You can also use the 12" knife as a straight edge as you sand down the joint compound after it dries. Take a shop light and hold it up to the side of the wall to reveal the imperfections as you sand it down.
Homer
homerb is offline   Reply With Quote
Old 05-18-2010, 11:44 AM   #8
Rewards Points: 150
It is even better to use the light when you APPLY the mud so you can see the problems you are creating that you will have to sand later.
Old 05-27-2010, 06:38 PM   #9
Use a curved trowel not a knife. Cover either side from the centre then use your 12" knife later to smooth out. Sounds like to much mud under the tape
masterofall is offline   Reply With Quote
Hardi plank installation - distance between butt joints? Scuba_Dave Building & Construction 25 07-21-2009 12:01 PM
Taping uneven butt joints! Lindsay8 Building & Construction 2 06-17-2009 12:08 PM
UGH! Trim joints are opening up! javan Carpentry 5 12-16-2008 06:05 AM
caulking butt joints on siding downunder Building & Construction 7 11-13-2008 03:56 AM
Butt Joints at new drywall and existing corner round VistaV Building & Construction 1 02-03-2008 09:36 PM
