Help Taking Down This Dryall Is A Bi$&? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-02-2013, 11:19 AM   #1
Rewards Points: 874
Help Taking down this dryall is a bi$&?
Taking down ceiling drywall in my garage 3/4" help up with nails and it is really really touch to get down ....looks like a long day. Just making holes and pulling it down ...any easier/faster way to do this ? Thanks
Mstrlucky74 is offline   Reply With Quote
Old 11-02-2013, 11:31 AM   #2
iminaquagmire's Avatar
Rewards Points: 338
Welcome to firefighting overhaul, haha. If you have something with a long handle that you can hook onto the drywall and pull with it might be easier. Something like a garden hoe would work. Otherwise if you can get leverage against something above with a long board as a lever, you may be able to do that. For example if you have a floor above the garage, stick a long 2x4 or something in between the drywall and subfloor and pry down.
iminaquagmire is offline   Reply With Quote
The Following 2 Users Say Thank You to iminaquagmire For This Useful Post:
gregzoll (11-02-2013), Gymschu (11-02-2013)
Old 11-02-2013, 07:22 PM   #3
Davejss's Avatar
Rewards Points: 746
Get a cat's paw and pull at least every other nail. Then you should be able to get the drywall down in fairly big pieces if not full sheets.
Davejss is offline   Reply With Quote
Old 11-02-2013, 09:42 PM   #4
Julius793's Avatar
That's right a halligan is the best tool in my opinion using the adze
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 11-02-2013, 10:47 PM   #5
Rewards Points: 6,652
Just go find a few neighborhood kids, then when they show up, hand them hammers and tell them that they get to knock a bunch of holes into the walls. Then all you have to do, is just pull the sections out.
Gyprock is a Byoch, when it comes to taking that stuff down. Regular drywall sheets are easy, if you have the right tools. A Roofers shovel works really well also, in pull the sheets off of the studs & off the ceiling.
Incompetent Contractor taking advantage ? (pictures) ford361 Kitchen & Bath Remodeling 11 06-21-2012 06:42 AM
taking down a wall and installing a new countertop danxp General DIY Discussions 7 10-18-2011 08:03 PM
Changing Kitchen Flooring from tile to Hardwood? Regarding taking cabinets up? doodleb1973 Flooring 3 07-27-2011 05:25 AM
invasive grass taking over Kentucky bluegrass annie68164 Landscaping & Lawn Care 18 04-07-2011 04:19 AM
Enclosed Patio taking up water profenx Building & Construction 0 10-12-2010 01:20 AM
