Help With Skim Over Plaster - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-10-2014, 03:25 PM   #1
hboogz's Avatar
Rewards Points: 97
Help with Skim over Plaster
All -
I have a small entrance/vestibule? area that is in need of TLC. Breaking all the plaster and subsequent lath is certainly an option, but for all those out there I have a question:
Based on the pics, is it recommened or possible to skim over this wall with lightweight compound to create a nice finished look ? If so, how do I properly get the compound to adhere? With a plaster primer ?
I'd also like to retain the plaster detail on the ceiling, although that appears to be tricky for a plaster n00b as my self -- curious to here tips from both the old and new timers.
Thanks,
Harry.
hboogz is offline   Reply With Quote
Old 01-10-2014, 04:31 PM   #2
Rewards Points: 5,974
Harry from pic one you need to test to see if the plaster is loose. It is kind of hard to tell if that is what is happening or that is the texture. If that is just texture you may need to sand down those real high spots. They don't have to be flat but to make them smaller will make skimming easier.
Old 01-10-2014, 04:34 PM   #3
Rewards Points: 13,300
With a house that old you can count on lead based paint.
Old 01-11-2014, 09:39 AM   #4
hboogz's Avatar
Rewards Points: 97
Thanks for the replies. ToolSeeker, I plan to scrap and sand down as much texture as I can. Once that's done, is there a specific type of primer i should place on the wall in order for the skimcoat to take ? I've heard the new ultralightweight joint compound is easy to apply, even with a roller. Don't know if that's recommended in this application.
Thanks,
Harry.
Old 01-11-2014, 10:36 AM   #5
You shouldn't need to use a prime to skim coat especially since your going to sand. To be honest I really like the ultra for skim coating. The roller method has not worked very well though unless the wall was really pretty smooth to start with. One thing about the ultra I have found is that if you thin it and don't use it all right now. Then like the next day it is very runny.
Old 01-11-2014, 11:32 AM   #6
Gymschu's Avatar
Rewards Points: 496
Here's a recent thread on the Painting forum that may be of help:
skim coating & painting
Plaster Skim Coat over Drywall Perry401 Drywall & Plaster 3 04-15-2013 06:00 PM
Plaster over Skim Coat Canoe Place Drywall & Plaster 0 08-22-2011 04:13 PM
Venetian Plaster FYI Plaster Ayn Painting 10 07-01-2010 12:26 AM
patching plaster skim coat thomase Building & Construction 2 06-30-2008 12:28 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 06:27 AM
