Help Sanding Marks In Joint Compound - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-11-2011, 05:41 AM   #1
help sanding marks in joint compound
my contractor finished the taping etc and there were some some slightly noticeable sanding marks
i primed and they were still slightly notceable
when i ask him about them them he said they would fill after 2 after 2 coats of paint
welll he's gone and they didn't fill after 2 coats of paint, they are not real notcable, actually i really thought they were ok after i painted until i put up a couple wall sconces
so how can i handle this? will a slight skim over the area help or fine ssand now? whats steps can i do to correct this or help it
thanx
bbillcee is offline   Reply With Quote
Old 02-11-2011, 06:02 AM   #2
DIY staff
Rewards Points: 7,174
You can fill them with lightweight Drywall mud---not a problem--you will have to repaint those touch ups with 2 coats of paint.
You have learned a lesson here----it is the painters job to do drywall touch ups after the primer goes on.
Often small imperfections get packed with sanding dust--and don't appear until the primer is on--
ll pro painters know this---and now you do,too.-----Mike---
bbillcee (02-11-2011)
Old 02-11-2011, 06:05 AM   #3
thank for filling me in!
Old 02-11-2011, 07:01 AM   #4
DIY staff
Learning by doing-----the best lessons--they should be---they cost the most---
Old 02-11-2011, 08:51 AM   #5
I just solicited a drywall quote. I noticed that thier standard services included:
Drywall to be screwed and glued (low V.O.C glue)
Quote includes:
o One spot drywall touch up after prime and before finish paint
o Scrape of floors from mud upon completion of work
o Shop vac angles, corners and window sills
o Plastic installed as needed to minimize dust
o Sweep floor with fine broom at time of sweep
o 11 month warranty visit
Drywall to be finished to a level four finish
I don't know, thought I would post in case anyone getting quotes has some extra info to ask their contractor. I have not had them do the work yet but they have done two large jobs for friends of mine.
ferris13 is offline   Reply With Quote
Old 02-11-2011, 09:27 AM   #6
Household Handyman
Rewards Points: 1,408
Interesting. I have been around a lot of dry-walling on job sites and have never heard of a "level 4 finish" or any number finishing. I'll have to get re-educated on that one.
Old 02-11-2011, 10:47 AM   #7
Thurman, yeah, I should go look that up...
http://www.nationalgypsum.com/resour...evisiting.aspx (first google hit)
Old 02-11-2011, 04:55 PM   #8
Drywall contractor
Rewards Points: 1,070
Level 5 is the top of the line, includes glaze coating all surfaces prior to sanding. Any drywall contractor worth a flip will include a touch-up after priming. Was a power sander used? Often it will leave some marks when a fresh pad is installed. Mesh screen tends to leave scratches, which is why I don't use it. Even a new sheet of paper on a regular pole sander can scratch at first. Using too heavy a grit, lightweight mud for the skim, any number of causes are possible. Paint MIGHT fill the voids IF a fairly heavy nap roller is used, but you should not have to make up for the contractor's error. He should come back and skim the areas and get them to where they are acceptable to your standards.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 02-11-2011, 08:01 PM   #9
it went very easy thanx!
The Following User Says Thank You to bbillcee For This Useful Post:
oh'mike (02-11-2011)
spackle versus joint compound... joeyboy General DIY Discussions 13 01-06-2016 06:09 PM
What To Prime Wood With to Accept Joint Compound? Lovegasoline Building & Construction 19 11-03-2009 06:04 AM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 11:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
Hairline crack in joint compound elbee Building & Construction 10 12-02-2008 06:57 PM
