Help With Replacing Backsplash - Cement Board Problem - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-08-2013, 08:58 AM   #1
Rewards Points: 155
Help with replacing backsplash - cement board problem
I want to replace all the cement board panels with new ones.
The problem is that the old cement board goes down about 3" below the top of the counter. We werent planning on removing counter/cabinets as this is way above skill level.
here is a picture:
at this point i am thinking i go buy a sawzall (as i will most likely use it for whatever) and just cut it nice and square so replacement pieces will be easy to pop in.
thank you for any feedback.
rygar is offline   Reply With Quote
Cement Board Questions trophywalleye Drywall & Plaster 17 06-29-2011 10:56 PM
Remodeling bathroom - question regarding cement board prontocruz Building & Construction 2 06-27-2011 06:11 PM
Cement Board -- Correct Install Method? unionmaid Kitchen & Bath Remodeling 9 01-09-2010 10:04 AM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
