Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-21-2011, 12:30 PM   #1
Help with repair
I have a curtain rod secured above my sliding glass door to the drywall, but my 12 month old pulled down on the curtain and now one of the attachment points has pulled from the wall.
It was secured by drywall anchors, which are now halfway out of the wall.
What would be the best way to repair this? I need it to stay in the same position, and of course it isnt near a stud.
mikereno1 is offline   Reply With Quote
Old 07-21-2011, 01:38 PM   #2
NACE Coating Inspector
mustangmike3789's Avatar
Help with repair
larger anchor or screw possibly?
mustangmike3789 is offline   Reply With Quote
Old 07-21-2011, 02:32 PM   #3
Help with repair
Could you take out the anchors, fill it with mud, let it dry. then put the anchor back in the same place?
larger anchor would mean larger screw would work. But that would mean the screw would have to fit in the hole of the curtain rod.
jburchill is online now   Reply With Quote
Old 07-21-2011, 02:33 PM   #4
Architectural Designer
AGWhitehouse's Avatar
Help with repair
I personally love toggle bolts...don't always work for the application, but when they do I don't hesitate.
Otherwise they make different size drywall anchors. Like mike suggested, maybe a larger diameter?
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 07-21-2011, 02:57 PM   #5
Help with repair
I was thinking of just doing the larger anchors as well. I will have to drill out the support bracket for the curtain for the larger screw to fit, but that shouldnt be that hard. A toggle bolt might be a good option as well.
Old 07-21-2011, 05:55 PM   #6
Help with repair
your curtain rod is adjustable correct ? i would fill the holes with setting mud a few coats , then either shorten or lengthen the rod an inch , or if not raise or lower it an inch to get fresh drywall .
oldrivers is offline   Reply With Quote
Old 07-21-2011, 06:03 PM   #7
Help with repair
definitely adjustable, but it is set up right now completely even compared to the other side and the wife wouldnt be pleased if I made them 'uneven'
If I cant get it to set strong enough I will have to move both sides I suppose
Old 07-26-2011, 03:33 PM   #8
Help with repair
NVM, i didn't read properly. tired to delete my post.
danimama is offline   Reply With Quote
Old 08-01-2011, 05:18 PM   #9
Help with repair
Clean the hole up, attach a piece of wood behind the drywall extending past two sides of the old dw, fill with mud or new piece of drywall then mud , sand smooth, prime, paint, attach rod holder through the mud/dw and into wood with screws to fit.
Just another option. Might be a little stronger.
Old 08-02-2011, 08:14 AM   #10
Help with repair
no matter what your going to have to use drywall mud to patch the holes so why not do a little demo/repair to make it better.. as Boman described would be the best way to fix it so it looks correct and will be stronger for the little one to tug on.
jarheadoo7 is offline   Reply With Quote
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 11:45 AM
Alternative for Dryvit for Repair scavuzzoj Building & Construction 5 07-07-2011 04:22 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Repair Compounds saggdevil Painting 3 04-25-2010 04:02 PM
What do you guys think of this roof repair job? darsunt Roofing/Siding 7 08-21-2009 09:43 PM
