Help!!! I Can See The Seams In My Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-20-2009, 10:03 AM   #1
Exclamation
Help!!! I can see the seams in my drywall
I have just hung new green board in my bathroom, and I used paper seaming tape for the joints. I mudded, and have sanded, and now I am putting on another layer of mud, which theoretically should be my finishing coat, but that is not seeming to be the case! The paper tape has holes in it, i would assume so that the mud will help the tape stick, but the tape isn't sticking, and it just seems to keep resurfacing through the mud? Very frustrated! I just want my Bathroom done! Can anyone help?
Justin
jusblaylock is offline   Reply With Quote
Old 05-20-2009, 10:11 AM   #2
Old School
Willie T's Avatar
Put the very good "SEARCH" feature of these forums to use. That subject is well covered in numerous areas... Probably no less than 200 posts.
Willie T
Old 05-24-2009, 08:00 AM   #3
Mud is to dry on the first coat. It also may be that you didn't embed it deep enough in the first coat. You need a minimum of three coats and maybe more depending on your skill level. Start with an 8, go to a 10, and then maybe a 12 or even bigger to finish. There are lots of posts on here if you take the time to do a search.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 05-24-2009, 11:05 AM   #4
Drywall contractor
Rewards Points: 1,070
If the tape is "blistering" away from the board, there was not enough mud under it to adhere it. You will need to pull it loose in the places it is blistering and get more compound under it. Then wipe down and re-coat over the tape...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 05-24-2009, 02:59 PM   #5
Rewards Points: 5,336
The situation bjbatlanta is describing is from pressing too hard on the tape. You should be using a 6" knife on these taped joints as a minimum. 10" is better as it spans the recess making it harder to press the tape down too much. With butt joints you just need to minimize the pressure on the seam. This is a learning curve situation. Second time around should be better.
Ron
Tags
drywall , durock , greenboard , mud , seams
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Wavy taping seams - Help (drywall taping) newbpainter Drywall & Plaster 10 05-15-2009 10:36 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Repairing cracked drywall seams pjm Drywall & Plaster 3 03-08-2009 01:34 PM
Drywall seams tenzo Building & Construction 13 08-14-2007 12:39 PM
