Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 11-25-2008, 11:43 AM   #1
Help with drywall stench
I handle remodeling for houses owned by banks & corps. We have one that presents a difficult problem. Mentioned in other posts, apparently, this house was built using the foreign drywall. It has a developing smell of sulfur.
Is there anyone in this group who knows of a solution other than replacing all the drywall which would be beyond the value of the house?
Any suggestions greatly appreciated.
Emmett is offline   Reply With Quote
Old 11-25-2008, 02:10 PM   #2
Moderator
Termite's Avatar
Perhaps Kilz or some other sort of stainblocking primer/sealer???
Old 11-25-2008, 02:20 PM   #3
bradnailer's Avatar
I've seen on home improvement shows where you can also add an odorizer to your paint. They've used it to remove the smell of cigarette smoke trapped in walls.
bradnailer is offline   Reply With Quote
Old 11-25-2008, 05:18 PM   #4
Thanks for the replies. What I'm hearing is that in 2005 when building material was so scarce, builders were buying material from foreign suppliers & the result is this stuff that smells really bad after a time.
I am trying to find out if anyone is familiar with it and if there is some solution other than replacing all the drywall.
This has to be the tip of the iceberg.
Old 11-25-2008, 05:57 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
You could seal the drywall with a shellac
It's what we use for smoke damage
If sealing it with a coat of Zinsser's BIN (pigmented shellac) doesn't seal the odor, then the next step is drywall removal and replacement
slickshift is offline   Reply With Quote
Old 11-26-2008, 10:39 AM   #6
I like the shellac a lot better than the replacement!
Old 12-17-2008, 10:04 PM   #7
Chinese drywall can be toxic. Is the copper tubing in the A/C black/tarnished? If so, the drywall could be offgasing sulfur. This could be a very serious problem and it is my understanding that the drywall must be removed.
Chinese Drywall is offline   Reply With Quote
Old 12-19-2008, 10:06 AM   #8
bradnailer's Avatar
I heard that when the Chinese make drywall, they use filtered sewer water.
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Drywall - Horizontal or vertical slinku2020 Drywall & Plaster 27 04-08-2010 01:40 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
