Help With A Bumpy Patch Job - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-17-2010, 12:26 PM   #1
Rewards Points: 79
Help with a bumpy patch job
I've been trying to patch some holes in my walls for a while now, and am having a load of trouble trying to get a decent finish on it. Basically, these holes are 12"x18" each from where intercoms were originally installed in all of the rooms of my house. The previous owner pulled out all of the intercoms and left the holes in the wall covered up by pictures, etc.
I cut and secured new drywall in the holes, but the taping and mudding is just making a mess. Initially, I had used regular paper tape, but was having problems with squeezing out too much mud and the tape lifting.
So, I scraped off all of the finish and tape and started over with ultra thin mesh tape. Now, however, it seems like that in order to get a decent/smooth finish, I'm sanding all the way to the point where the tape is partially exposed.
Any tips on how to dig myself out of this hole? I've been taping and scraping on and off for over a year, and need to get the rooms painted eventually.
Thanks,
Mike
tigereye is offline   Reply With Quote
Old 01-17-2010, 12:42 PM   #2
big box stores,lowes here,carry a metal mesh adhesive backed square patch tha come in diff sizes. Have used them with a first light skimcoat of durabond 90. Pull this coat tight like a skimcoat. then work your way out with redymix drywall compound sanding between coats. I use a 12" knife thru this. get out past edge of patch at least 8" feathering each coat. good primer, point up and sand ,good primer ,paint. if needed patch can be cut to fit
Old 01-17-2010, 04:31 PM   #3
Remodeling Contractor
Try not over sanding. Sand only the high ridges for the first two coats. Even these may be removed with a taping knife. Tape with wider knives each successive coat. Feather sand the last coat.
Old 01-17-2010, 04:33 PM   #4
I suspect 12x18 he will need to start with wide knife for even coverage
Old 01-17-2010, 06:08 PM   #5
firehawkmph's Avatar
Rewards Points: 1,800
Tiger,
If you have been messing with these for over a year, you might want to call a taper in the area that will do small jobs. He'll have it done in no time at all and shouldn't cost very much.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 09:14 PM
Painting Drywall Patch markospencer Drywall & Plaster 3 12-30-2008 06:25 AM
Foundation Patch: Hydrolic Cement?? roztom Building & Construction 38 09-07-2008 11:22 PM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 12:16 PM
Floor patch HomeDepot23 Flooring 2 07-24-2008 07:03 AM
