Help With Angled Stairway Wall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-21-2013, 08:25 AM   #1
Help with angled stairway wall
My husband and I are drywalling our stairway and need some help on laying out the drywall. We need to drywall on top of the existing stairway skirt (it is pretty thick and continues below the stairs. The only way to pull it out is to tear out the stairs) so the wall is angled on top and bottom. I've attached a picture of what it looks like so you can see.
We're just not sure how to lay out the drywall. Should we do the sections vertically or horizontally? Should they be laid out on an angle so they are resting on the skirt board (which will mean the first and last pieces are cut to match the top and bottom angle)? Should they be laid horizontally and level (which doesn't make much sense to me but there is probably something I'm missing).
Any help is GREATLY appreciated since this one has me stumped. I've tried to Google it without much luck.
Thanks!
vonatah
vonatah is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Trimming Out Stairway with Wall Stringers agreif Carpentry 8 08-13-2012 11:17 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
