Hardibacker Cement Board Install - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-01-2010, 04:33 PM   #1
Hardibacker cement board install
I will be remodeling a bath wall replacing green board backing with Hardibacker cement board.. Questions:
At the corners where the cement boards meet, is it necessary to run a strip of alkali resistant tape down the middle and skim coat the tape with thinset? Or can I just caulk the corner and tile over it?
Hardi says their Hardibacker does not require a vapor barrier (i.e. plastic sheeting) under the Hardibacker first.. What do you guys say?
Thanks.
billyg is offline   Reply With Quote
Old 07-01-2010, 06:22 PM   #2
DIY staff
Rewards Points: 7,174
I don't use Hardi Backer ,only Durrock. However the mesh tape on corners and seams is installed as you tile---If you apply the tape and imbed it before you tile you may end up with a 'hump'
Making it almost impossible to get the tile flat.
There are many here who use Hardi--Let's see if it's any different.---Mike---
what waterproofing substance on cement board in bathroom(can't find Red Guard) Limit54 Building & Construction 15 11-19-2009 06:30 PM
can we install cement board(wonder board) sajidshah Flooring 20 09-17-2009 10:40 PM
Cement hardy board tmiles2246 Flooring 9 05-11-2009 04:10 PM
XPS foam board between basement slab and cement board for ceramic tiles jpsmith Flooring 4 02-10-2009 08:17 PM
particle board / hardibacker fish3211 Flooring 4 08-10-2005 08:32 PM
