Hanging Horizontal Drywall By One Person - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-05-2011, 08:57 PM   #1
Hanging horizontal drywall by one person
Is it possible to hang 12 foot 1/2" drywall horizontally on the walls by an individual (especially the upper 4 feet)? If so, how? I have a drywall lift but it only appears to be good for the ceiling.
Are 1 1/4" screws good for 1/2" drywall?
What is the longest that 1/2" comes in? The local store looked at me very funny when I asked for 14 foot sheets.(almost like I'd just stepped out of a time machine)
gulbworks is offline   Reply With Quote
Old 09-05-2011, 10:15 PM   #2
Rewards Points: 6,652
That size, you should rent a drywall lift, otherwise, you can cut the panel in thirds, or hang vertical Easier with the lift, or just call a couple of buddies. If this is your first time doing, it is cheaper to just pay a crew to hang and tape.
Old 09-06-2011, 07:21 AM   #3
I've done some before but always had help hanging plus I rented a lift to do the ceiling. The problem now is that I'm working at my cottage and most of my friends are a bit too old to ask them for help.
I bought one of those $150 lifts and was able to do the ceilings but the problem for me now is how to do 12' horizontal sheets on the top half of the walls. Will a lift work for the walls? If so how?
I intend to get someone to mud. I have done it before but I'm painfully slow.
thanks, Gulb
Old 09-06-2011, 08:33 AM   #4
Old School
Willie T's Avatar
You might want to try something like this.
The 'buttboards' are just a smarter way to do butt ends..... you can go ahead and hang the old way and fight with the 'butt bulge' as most of us have in the past. That's certainly your choice.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
Clutchcargo (09-06-2011)
Old 09-06-2011, 09:12 AM   #5
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,346
Interesting! That's a great working-solo trick.
So by not ending the drywall on the stud, it will minimize the bulge?
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 09-06-2011, 09:16 AM   #6
Thanks Willie,
It looks like the buttboards are 1x4. Good idea. I have one wall longer than 12 feet so I'll use them there. It took me a while to understand what the 2x4's were for but I see they are for supporting the sheet and adjusting the height (only one nail in each). I was hoping to use my lift for the walls. My lift is a cheapie and doesn't angle very far vertical. I'll try both methods and declare a winner!
gulb
Old 09-06-2011, 04:25 PM   #7
Too Short? Cut it Again!
Why 4x12 if you are trying to do this yourself? Between 1/2 inch thick 4x8 and 4x12 you have a 28 pound difference just in sheet weight. 4x12 is 82 pounds and 4x8 is 54.
Old 09-06-2011, 04:53 PM   #8
Rewards Points: 150
I take a 2x 4- 8ft, rip the side of it to a 10 degree angle with the angle back towards the wall when I screw it to the studs like the pic above. I put the drywall on milk cartons(the steel or plastic kind) with the paper face to the wall. Flip it over on the 2x 4 and adjust it according to where the studs fall. If you are strong enough to handle the 4x 12 drywall, this system makes it real easy to install by one person.
FWIW, the largest drywall I ever had the displeasure of working with was 4x 16 5/8" fire rated. I hauled 6 railcars of it in one of the local malls. It took me and another dimwit a week to stock it.
TrapperL is offline   Reply With Quote
Old 09-06-2011, 07:24 PM   #9
Because obviously you were lazy and only working 4 hour days, with breaks. I honestly have never seen a piece of 4x16x5/8 but once. I couldn't fit sheets that long easily into restoration project without cutting them down first. But why did it take you a week? With one under each arm at only 141 pounds and some ounces each?
And why. I didn't work on industrial so this may be typical fire code or something but 16' sheets seem inhumane if the goal was to save on mud and tape. Bet nobody messed with you accumulated muscle mass after hours! Did you pick up an toss Honda Civics for free drinks?
Old 09-06-2011, 08:00 PM   #10
deja-vu sdsester Drywall installation...longer better?
Old 09-06-2011, 08:35 PM   #11
I like the longer sheets to reduce the number of joints especially butt joints. I would like to get 14 foot sheets but they are a thing of the past around here.
I was actually wondering how much these sheets weigh. My wife and I can easily handle the bottom 12 foot.
Old 09-06-2011, 08:41 PM   #12
[quote=TrapperL;722557]I take a 2x 4- 8ft, rip the side of it to a 10 degree angle with the angle back towards the wall when I screw it to the studs like the pic above. I put the drywall on milk cartons(the steel or
good suggestion for installing alone. I can easily lift the sheet up from the milk cartons but my problem would be getting the sheet from the next room and putting it onto the 2x4 and cartons I think. I'll give it a whirl. All great one man ideas on this forum.
Old 09-06-2011, 09:19 PM   #13
Old School
Willie T's Avatar
Originally Posted by gulbworks View Post
Thanks Willie,
gulb
BUTTBOARDS are NOT just 1x4's. RESEARCH the subject to find out how to MAKE or BUY a buttboard.
Willie T
boman47k (09-13-2011)
Old 09-07-2011, 05:39 AM   #14
Thanks Willie, I looked them up and all I can say is that you learn something new all of the time.
I called a rather large building supply which specializes in drywall and they had never heard of them. It looks like we are in the dark up here. I'll have to make mine I guess. As I only require a few I wish that I could have bought them.
Old 09-11-2011, 04:16 PM   #15
Drywall contractor
Rewards Points: 1,070
It is POSSIBLE to hang 12' sheets "solo" if you're used to hanging and are in reasonably good shape. I'm in my late 50's and can still do it, though I prefer to have a helper these days. (And 14' sheets are available at a drywall supply company. If you don't have a lift (I THINK you can use them on the wall, though I've never used one), tack nails across the top edge of the sheet so when you get it butted to the ceiling you can drive them into the top plate(s) to hold the sheet until you finish fastening it. Of course I'm "old school" and use nails and glue on wood framing, so it would be hard to use screws (1-1/4" are fine, by the way). Willie's method suggested above will likely work fine. Just more time consuming (but less strain on the old back)....
Best of luck
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Hanging Drywall in an attic Graye2 Drywall & Plaster 1 02-07-2011 06:42 AM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Hanging drywall Question avtck Drywall & Plaster 6 01-05-2010 06:21 AM
Hanging Drywall ??????? mjkpainting Drywall & Plaster 11 04-23-2009 04:01 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
