Hanging Drywall Vertical On Basement Wall ? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-27-2010, 07:54 AM   #1
Hanging drywall vertical on basement wall ?
Basement finishing project with 16 oc studs and 1/2 inch gp durarock wallboard. The wall heights are just under 8 fett, which would allow me to hang wallboard vertical and eliminate all butt joints....make life real easy!
My question.... is this going to cause me any problems? Is there a reference guide that provides for installing sheetrock in this manner?
Thanks!
Oxymoron is offline   Reply With Quote
Old 01-27-2010, 01:56 PM   #2
General Contractor
You will find plenty of information by clicking on the link below:
www.gypsum.org/pdf/GA-216-07.pdf
ARI001 is offline   Reply With Quote
Old 01-27-2010, 10:20 PM   #3
firehawkmph's Avatar
Rewards Points: 1,826
Oxy,
I do basements like that. I would normally hang drywall horizontally, but in a basement where I can eliminate the butt joints I do it. It doesn't present any problems with the drywall. Just make sure you lay out your studding properly. Also, make sure you hang the panels plumb. Don't rely on the floor, the always seem to run off.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-28-2010, 07:22 AM   #4
Thanks guys....vertical it is!
Old 02-04-2010, 10:58 AM   #5
Drywall contractor
Rewards Points: 1,070
Horizontal is preferable from the standpoint that the joints aren't as likely to show under intense lighting and are little easier to finish (less mud also). But vertical is acceptable....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
How tight is too tight for a new basement wall? vseven Building & Construction 16 01-07-2010 09:50 PM
Best way to temporarily cover an unfinished wall for art hanging? datdere Building & Construction 7 12-17-2009 07:15 AM
Leaking Basement Wall MStocks Building & Construction 3 10-29-2009 10:57 PM
Repainting wall in basement color advise Dionysus Interior Decorating 2 12-25-2008 08:17 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
