Hanging Drywall In Partially Finished Basement - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-04-2012, 07:03 PM   #1
KBG
Hanging drywall in partially finished basement
I'm starting to finish my partially finished basement and I am not sure where to start with the drywall since there is already some pre-existing drywall. I hear that starting with the ceiling and then doing the wall is best but in mycase some of the walls are done and the ceiling is not. Do I start by doing the ceiling and then then new walls or do I finish the walls and then do the ceiling. See photos.
KBG
Hanging drywall in partially finished basement-dsc_0832.jpg   Hanging drywall in partially finished basement-dsc_0834.jpg   Hanging drywall in partially finished basement-dsc_0830.jpg   Hanging drywall in partially finished basement-dsc_0831.jpg   Hanging drywall in partially finished basement-dsc_0833.jpg
KBG is offline   Reply With Quote
Old 03-04-2012, 07:08 PM   #2
Rewards Points: 14,278
It should be ceiling first, the top of the walls then the bottom of the walls.
The walls help hold up the ceiling.
Old 03-04-2012, 07:40 PM   #3
Not to hi-jack this thread but I also have the same issue. The previous owners had dry-walled the walls only, they where going to do a drop ceiling for ceiling. I know you should do the ceiling first, then the walls. Will their be any adverse effects ? Can I cut 1/2 out of the top of the dry-wall to do the same effect ?
jsmithis101 is offline   Reply With Quote
Old 03-04-2012, 08:52 PM   #4
Rewards Points: 512
ya ceiling first, its just tough getting your ceiling sheets up tight with the wall board. you could cut 1/2" all the way around and it would correct it but would be a pain and alot of moving around on the ladder. i'd just board it and prefill mud it and caller a day
princelake is offline   Reply With Quote
Tags
basement remodeling , drywall , home improvement
Finished basement leaking drywall strategy bbruns1 Building & Construction 5 09-25-2011 06:09 PM
Considerations for mold free finished basement in Massachusetts? Ekc General DIY Discussions 3 09-23-2011 09:22 PM
Partially finished Basement HVAC l22 HVAC 1 01-24-2011 12:22 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Moving ductwork to accomodate finished basement Badfish740 HVAC 1 01-13-2010 03:11 PM
