#1 |
Hanging Drywall to a finished Ceiling, Seam Questions?
I'm renovating a bathroom and I gutted the walls, but left the existing popcorn ceiling, and I will be hanging drywall (green board) up to the finished ceiling and I'm wondering the best way to finish the joints were the new green board meets my popcorn ceiling.
Do I need to scrape 1" to 2" inches of popcorn off the ceiling and tape it or is there some easier way to finish the seam? |
#2 |
Advice worth 2 cents!
I have no idea of what you really want to accomplish but,..
Don't round any corners, do the most professional job you can and make your ceilings look like they belong in the White House! __pete ps.....popcorn is for theaters!
---pete |
#3 |
Tool Geek
It will take 15 minutes to pull down the popcorn ceiling and hours to make an overlay look 'right'
As Dr Laura says "Now do the right thing" .
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. & Stay Safe .....Bob Lavery |
#4 |
Renovation Contractor
Worker B,
Yes, you will have to remove the popcorn so that you can tape the corners. Handy Pete, what he is talking about is he is leaving a ceiling in and replacing his walls only. However when he butts the wall drywall up to the ceiling he will have to tape the corners where the wall and ceiling come together. WorkerB you will have to scrape more than just a couple inches though because the tape alone is about 1 - 1 1/2" after being folded. This is also a spot where you will be taping out at least 6" or more depending on how the tape lays and how smooth the transition so as Pali Bobn pointed out just go ahead and remove the exisitng popcorn from the ceiling all together. You will probably be quite effective by scraping it off with a 10" or 12" broad knife however the determining factor of how easy it will come of will be how many coats of paint is over it. Sometimes (once again depending how much paint is on the ceiling) spraying water ahead of scraping can penetrate and make the popcorn come off like frosting. After removing the texture you will more than likely have some ceiling repair to do because during the removal of the texture you WILL pit the ceiling in spots. Also another justification for removing the texture is that a lot of times it is difficult to match the existing texture even if you were the one who origionally sprayed it. Environmental conditions change and can effect the final outcome and look enough to make you regret not removing 35 ot 50 square feet of texture. I hope this has helped and if it hasn't please feel free to post some follow up questions. Good luck and be safe!
James D. Van Raden Owner, Paragon Renovations Moorhead, MN/ Fargo, ND To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "Committed to providing the finest renovation services available"
#5 |
As a tradesman, I am great fan of getting the correct trade to the correct job!
Okay, you want to do this yourself AND LEARN SOME NEW SKILLS, GET SOME SATISFACTION ETC... Why not then! Let me get this right? You have installed nice new walls but now you want to try and bodgey the nice new walls into the crappy old ceiling! Is that about right? PUT IN A NEW CEILING AS WELL and you will finish up with a nice job. Try and marry into the existing crappy ceiling and you'll still have a crappy ceiling! NICE. |
#6 |
Since noone has actually given you an option besides basically replacing the ceiling, I might as well throw /something/ out there, even if its not your best option. =)
Obviously you WILL have to remove 1-2" of the popcorn ceiling around the border of the bathroom to make the proper union between the walls and the ceiling... However, if you cut that 2" of popcorn off and do a good job (meaning your inside edge is straight, you could seal your wall/ceiling union properly, then add some PVC crown molding, mating it with the edge edge of the popcorn ceiling. It would hide the corner, and you will not need to do additional work to the ceiling besides removing the ~2" of popcorn ceiling around the border. Still, as the others have stated, replacing the ceiling is ultimately the "best" option, though will add additional costs. Personally, my biggest fear would be accidentally damaging the work you have already done up to this point if you try replacing the ceiling. |
| Display Modes | |
| Drywall ceiling in basement using floor trusses | ralphfravel | Drywall & Plaster | 10 | 04-03-2009 08:12 AM |
| finishing a drywall ceiling | mmhendrie | Building & Construction | 12 | 03-17-2009 10:11 AM |
| Hanging drywall basement ceiling from engineered wood I-beam joists | ja_trusty | Building & Construction | 6 | 10-09-2008 12:06 PM |
| Drywall thickness on ceiling question. | Doug Crf | Building & Construction | 3 | 08-28-2006 06:47 AM |
| Basement Ceiling- Combo of Drywall and Drop ceiling? | H Thomas | Building & Construction | 5 | 03-27-2006 09:27 AM |
