Hanging Drywall In Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-16-2010, 07:25 AM   #1
Hanging Drywall in ceiling
Why is it important to hang drywall cross the ceiling joist instead of along them. I installed about 10 12' sheets already along the joist. do I need to take them down and hang them across the joists?
Gifts2all is offline   Reply With Quote
Old 07-16-2010, 03:02 PM   #2
Registered User
Rewards Points: 526
Table #1, and read the footnotes: http://www.gypsum.org/pdf/GA-216-07.pdf
So..... only replace it with 5/8" if 1/2" on 24" o.c. running with the joists and water based textured..
Be safe, Gary
Old 07-17-2010, 10:04 AM   #3
Drywall contractor
Rewards Points: 1,070
It is recommended to hang horizontal to the joints, but due to joists changing direction it is sometimes necessary to run with the joints in certain situations to prevent having to butt non-tapered edges to the tapered edge of the drywall. So it is acceptable. I wouldn't tear down what' already up at this point.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
drywall for vaulted ceiling mdudu Roofing/Siding 5 03-02-2010 12:24 AM
Using drywall for Drop Ceiling rickkeeter Drywall & Plaster 8 02-13-2009 07:52 AM
drywall for the ceiling genner Drywall & Plaster 8 01-11-2009 09:29 AM
Plaster Ceiling and drywall dprasan Remodeling 6 02-05-2008 11:34 PM
