Hanging Drywall On Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-06-2009, 05:48 PM   #1
Hanging drywall on ceiling
I'm hanging drywall for a basement ceiling using 5/8". For areas where there are heat ducts in the ceiling is it OK to have the screws 24" apart?
Thanks!
Bob007 is offline   Reply With Quote
Old 08-06-2009, 06:43 PM   #2
Registered User
Rewards Points: 5,244
Depends on the application. With no glue-- Single nail or screws =7" edges, 7" field.
Double nail or screws- = 12"o.c. w. 2- fasteners 2----2-1/2" apart
With glue --- Framing 16" o.c. - 16" nail or screw
Framing 24" o.c. - 12" nails, 16" screws
Find it here, page 9: http://www.gypsum.org/pdf/GA-216-07.pdf
Be safe, G
Old 08-07-2009, 04:12 PM   #3
Thanks for the info G!
Bob
Old 08-09-2009, 12:44 PM   #4
Drywall contractor
Rewards Points: 1,070
Definitely use adhesive. You can use fewer fasteners thus less chance of screw/nail "pops" down the line and makes for a more solid job all around.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 08-17-2009, 12:13 AM   #5
Rewards Points: 256
5/8ths drywall is hung on 24 centers all the time. juts make sure you hang the drywall in the right direction. do not railroad the sheets or it wont matter how many fasteners you put in. the weight will cause it to sag overtime.
oldrivers is offline   Reply With Quote
Old 08-17-2009, 08:05 AM   #6
Originally Posted by oldrivers View Post
just make sure you hang the drywall in the right direction. do not railroad the sheets
What does "railroad the sheets" mean?
Old 08-17-2009, 08:48 AM   #7
Rewards Points: 6,652
Stagger the joints, instead of running them in a way, the joints all run along the same line with no break between.
Old 08-17-2009, 08:56 AM   #8
Running the sheets parallel to the joists.
jerryh3 is offline   Reply With Quote
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 10:50 AM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Hanging drywall basement ceiling from engineered wood I-beam joists ja_trusty Building & Construction 6 10-09-2008 12:06 PM
Hanging Ceiling Drywall AFTER Wall Drywall? mfleming Drywall & Plaster 10 10-06-2008 04:32 PM
Hanging Drywall over ceiling tiles bjorgens Remodeling 4 12-19-2007 01:59 PM
