Hanging Drywall On Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-05-2011, 07:00 PM   #1
Hanging drywall on ceiling
How do i get a straight cut alng the joyce for my old drywall to meet my new drywall on my celing
LISA DUNCAN is offline   Reply With Quote
Old 07-05-2011, 07:06 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Have no idea what you are trying to say or do.
XXX
Old 07-05-2011, 08:21 PM   #3
Too Old
You must mean Joist. Take your time and use a sharp knife, or cut along the joist and use a 2x for backing.
havalife is offline   Reply With Quote
The Following User Says Thank You to havalife For This Useful Post:
oh'mike (07-05-2011)
Old 07-05-2011, 09:26 PM   #4
DIY staff
Rewards Points: 7,174
Often adding a 2x4 along side the joist is the easiest and fastest method--that way you can just saw off the old drywall alongside of the joist.
If you have the patience and a steady hand,you can cut the drywall right down the center of the joist.
Old 07-05-2011, 10:31 PM   #5
MikeKy55's Avatar
Rewards Points: 254
I did it this way when I put a sheet up and the edge wasn't dead center on the joist. I took a 4 foot level and drew a line across the edge to be cut and then used a utility knife with a new blade.
MikeKy55 is offline   Reply With Quote
Old 07-06-2011, 01:11 PM   #6
Drywall contractor
Rewards Points: 1,070
Take a nail and find the edge of the joist, then measure back 3/4" to the center on both ends of your 4' sheet. Draw the line and you'll have the center of the joist all the way. Or oh'mike's method is perfectly acceptable. Just be sure to get the new piece of wood flush with the old so the pieces line up....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Installing Drywall Ceiling daytrepper Drywall & Plaster 10 02-10-2011 01:52 AM
drywall basement ceiling Dgggless Drywall & Plaster 3 11-14-2010 10:43 PM
framing ceiling for drywall artlover13060 Drywall & Plaster 1 07-04-2010 11:25 AM
Basement drywall ceiling and walls questions enero Drywall & Plaster 6 06-05-2010 04:13 PM
Using drywall for Drop Ceiling rickkeeter Drywall & Plaster 8 02-13-2009 08:52 AM
