Hanging Drywall Around Stone Fireplace. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-04-2010, 05:31 PM   #1
Rewards Points: 27
Hanging drywall around stone fireplace.
Looked on the web and didn't turn anything up. We have a stone fireplace in our basement. What would be the proper way to drywall around it. I don't want to cover the fireplace. Also, the mantle does the drywall actually go behind it or around it? In our upstairs fireplace it goes behind, but it's a two piece mantle in the basement and is mortered to the stone. Thoughts and suggestions? Thanks
kossuth is offline   Reply With Quote
Old 06-04-2010, 07:24 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Install your drywall to within several inches of the stone, stopping on a stud of course. Then measure from the edge of the last panel you installed to whatever point in the stone is furthest from the that already installed edge. Cut you last piece and hold it tight against the stone and allow it to overlap the previous panels edge. Be sure your last piece is straight up and down. Use compass with a pencil and place the point against the stone and use the pencil to draw your irregular line on the drywall. This will scribe the irregular edge for you. Go back and trim away the scribed line and you should have a perfect fit against the irregularities of the stone.
XXX
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 09:50 AM
Removed tile around fireplace, drywall underneath?! Fropitar Building & Construction 37 06-02-2010 08:11 PM
Replacing slate with stone on a fireplace Debbiesue Building & Construction 4 09-04-2009 04:58 PM
Cultured stone around fireplace MichaelP Building & Construction 10 06-21-2008 05:38 AM
