Hanging Drywall On 8.5 Foot Walls - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-26-2012, 05:28 PM   #1
Hanging drywall on 8.5 foot walls
I have 103 inch walls in my basement (8.5 footers), and I already bought 40 sheets of 1/2 8x4 foot sheetrock, I've been hanging them horizontally, one at bottom, one at top, all the way to the joists (I'll be hanging a drop ceiling later) and in the middle I have 7 inches. I've been scoring long strips of 7 inches from sheets, and they stand out more, because they come into contact with concave edging on top and bottom sheets.
I did 1/3 of my basement this way already and only today I found out about special order 54 inch drywall I could have used. Too late, as I'm not about to unscrew 1/3 of my basement and start over. It's just going to make it so much harder taping the joints in the middle so they don't stand out as much? Should I do the rest of the basement with the 7 inch piece at the top instead of putting in the middle as I've been doing?
Thanx.
motopokep is offline   Reply With Quote
Old 04-26-2012, 05:58 PM   #2
I think I found the answer to my question:
I'll order 54 inch drywall and combine it with the 48 inch sheets I already have for a total of 102 inch walls (I'll be dropping a ceiling which will cover the inch).
Still, the 7 inch seam I already hung in the middle, should be fine taping over, right?
Old 04-26-2012, 06:16 PM   #3
Rewards Points: 13,960
Made yourself a whole lot more work then needed.
Wider sheetrock would have been the ideal way to go, now your stuck with trying to cover seams without tapered edges. Not a fun job.
If I had the same materials you had to work with I would have installed the top piece first, the next one tight to it and had the narrow stip at the bottom
with the tapers facing each other. Not idea but way easer then trying to hide cut edges.
Old 04-28-2012, 07:02 PM   #4
Rewards Points: 512
i would have bought 10' sheets and hung them vertically
princelake is offline   Reply With Quote
Old 04-28-2012, 08:05 PM   #5
Rewards Points: 85
I would have started at the top and put a 6" or 8" baseboard at the bottom to cover the lower seam.
housegsx is offline   Reply With Quote
Old 04-29-2012, 03:03 PM   #6
You will have a situation similar to taping butt joints. Flair them out 14" each side. Not much else you can do at this point
masterofall is offline   Reply With Quote
Old 05-03-2012, 08:45 PM   #7
Drywall contractor
Rewards Points: 1,070
Hanging all 8' sheets horizontally makes for a lot of butt joints besides the 7" rip in the middle you have. You could have actually gotten 9' sheets from a drywall supply and only had 6" of waste by standing them up (as opposed to 18" with 10' board). If you're proficient enough to finish butt joints to a proper level, the 7" rip won't be a problem. You'll just need another bucket or two of mud....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 05-03-2012, 09:01 PM   #8
Rewards Points: 2,212
What you did is what we did before 54" sheets came out. No problem, just mud it all up nice and float it out.
mae-ling is offline   Reply With Quote
Old 05-04-2012, 08:37 PM   #9
Rewards Points: 154
For the rest of the basement, couldn't you just hang the 8' pieces from the floor vertically? You would have a 6" gap at the top but just have your drop ceiling at least 6" down from the floor joists. An 8' drop ceiling height is still pretty good. This way you'll have 1 vertical tapered joint every 4 feet...easy-peasy.
BTW: the drywall that you already put up...did you stagger the joints? I'm sure you most likely did, but if not, I'd be inclined to pull it all down and re-do it. Chalk it up to experience.
pete0403 is offline   Reply With Quote
Old 10-12-2014, 09:05 AM   #10
Rewards Points: 2
Easy fix
Use 3/8 drywall for the 7 inch strips. I use 1/2 strips on my 5/8 walls. Works great! Professional sheetrock buddy shared this tip. Another tip is to use cardboard shims (Home Depot carries them 1 1/2x 47") one stud back from your butt joint. both sides of joint. Puts very small bow in rock giving you a east butt joint.
retiredsparky is offline   Reply With Quote
Old 10-12-2014, 10:07 AM   #11
Rewards Points: 5,974
Sparky is absolutely correct if you have a 7" gap it needs to 3/8" so you can fill it in. If you use 1/2" it will stick our so far you will never hide it. Put the 48" piece on top the 54" on the bottom and since you should leave an inch gap at the floor that your baseboard will cover and your good to go.
Just read where your ripping your strips from the 1/2" sheets this really won't work as stated and also you have a tapered edge against a non tapered edge.
To hang vertical is also a bad idea unless your house has perfect framing, and I have never seen one that did, this will lead to other problems. A stud is 1 1/2" wide, that leaves 3/4" space to screw each sheet of drywall. Draw 2 lines one a piece of paper, this is your stud, now draw a line down the middle. Now you see how much the drywall is supported, and remember you can't screw right in the edge. Now move the line say 1/4" one way, doesn't leave much to screw to does it? Now you will need to put in blocks on the sides of the studs so you have something to screw to.
And believe me a house that the framing is only out 1/4" would be a miracle.
Hanging drywall in partially finished basement KBG Drywall & Plaster 3 03-04-2012 08:52 PM
Drywall hanging HELP!! topflitecop21 Building & Construction 8 01-16-2012 09:21 PM
Drywall question- patching walls of 2 thicknesses cbrc5eric Building & Construction 1 11-12-2010 01:26 PM
Basement drywall ceiling and walls questions enero Drywall & Plaster 6 06-05-2010 03:13 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
