10-02-2008, 11:42 AM
#1
Hanging Ceiling Drywall AFTER Wall Drywall?
Hello.
I know you are supposed to hang ceiling drywall before the wall drywall, but I need to finish the walls and leave the ceiling open for a little while then come back and finish it later.
Can this be done?
What are the problems associated with doing this?
Matt
10-02-2008, 11:59 AM
#2
the Musigician
search the threads here. most agree doing the ceiling first (then the walls help support the ceiling sheets) however, i have the same problem on one side of my new dining room. i needed an interior wall fast. if secured properly and using crown moulding mounted to wall studs, i don't see me having any problems. if no moulding is used, you MIGHT have sagging down the line. sagging is why i plan to buy 5/8" CEILING drywall (it's 'stiffer') if you use this, i forsee no problems. but what do i know? i'm just a mouse.....
DM
10-02-2008, 05:46 PM
#3
Drywall contractor
As long as you have nailers on 16" centers (minimum) you will be fine even with 1/2" board.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
10-02-2008, 05:50 PM
#4
the Musigician
oops, i should have mentioned mine are 24" OC, hence the need for 5/8" ....sorry.
DM
10-02-2008, 06:02 PM
#5
Drywall contractor
Makes sense then. No need in hanging 5/8" (especially overhead) if you don't need to........
10-02-2008, 11:52 PM
#6
I have done it before and it is ok. I would suggest the moulding as well. It makes less floating and gives you a nice straight line to do a seperate color on the wall and just overall looks nicer.
10-03-2008, 06:00 PM
#7
Custom Cabinet Maker
some good ole PL adhesive along with screws will help alot
10-06-2008, 03:00 PM
#8
The funny thing is, even with putting the drywall on the walls after the ceiling, many times you still end up with gaps due to uneven ceilings and walls.
10-06-2008, 03:29 PM
#9
Oh no, every house in the world is built perfectly square and veryone cuts thier drywall perfectly
10-06-2008, 03:32 PM
#10
the Musigician
nothing funny about that!
DM
10-06-2008, 04:32 PM
#11
Further to that, I've never had any cracking issues in the corners where gaps existed between the ceiling and the walls. As long as the ceiling piece is supported well with enough screws, I don't forsee much of a problem... You could leave half an inch space at the top of the walls and slide in the ceiling drywall if you want but it will complicate things.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
