-   -   Hanging Ceiling Drywall (http://www.diychatroom.com/f101/hanging-ceiling-drywall-140254/)
Lollymagoo 04-14-2012 12:21 PM
My husband and I will be hanging ceiling drywall (in the kitchen) for the first time next weekend...
Everything I've read says to use 5/8" thickness panels, to prevent sagging. However,the kitchen ceiling ties directly into the living and dining rooms, which have the original 1/2" ceiling sheetrock panels. We can't do any strip blocking under the (24" apart) roof trusses because of this also.
So, we purchased 1/2" USG Mold Tough gypsum sheetrock panels, instead of 5/8" panels. We're going to glue and screw (hmm...that didn't sound right! :blush:).
Are we in danger of a sagging ceiling?? Any advice?
DangerMouse 04-14-2012 12:34 PM
Are you saying they're 24" OC and you want to put 1/2" up there? Is this being permitted? I do not think the inspector will OK that. 5/8" will likely be required.
DM
woodworkbykirk 04-14-2012 12:38 PM
5/8" board does work better for ceilings but isnt neccessary, glue and screw the board plus use more screws closer together to help prevent sag. standard practice is 4 or 5 screws per truss or strapping . up the screws to 8" o.c and you should be fine
princelake 04-14-2012 01:11 PM
i believe you may possibly have problems. the only 1/2" rated for 24" is sag resistant and ultra light drywall.
DangerMouse 04-14-2012 01:41 PM
Originally Posted by woodworkbykirk (Post 898802)
5/8" board does work better for ceilings but isn't necessary
....tell that to MY building inspector... see how far it gets you... :laughing:
5/8" fire-X required.
DM
7echo 04-14-2012 07:39 PM
Use ceiling board instead. Stiffer than regular drywall, I think it is specified for 24" centers. Here is one option...
http://www.nationalgypsum.com/produc...29%2000-06.pdf
bjbatlanta 04-15-2012 10:08 AM
The new ultra light IS rated for 24" centers, even with water based texture applied. Code varies from area to area, but around here 5/8" is only required in some garage applications. And that varies by county and even municipality in some cases. I would guess if the rest of your house has 1/2", it is allowed. Check with the building dept. if unsure....
Gary in WA 04-15-2012 11:19 PM
1/2" USG Mold Tough-----------If applying a water-based texture, the framing requires 16"o.c., not 24"", see footnote "D": http://www.usg.com/rc/data-submittal...tal-WB2390.pdf
Gary
bubbler 04-16-2012 07:50 AM
Originally Posted by Lollymagoo (Post 898785)
The kitchen ceiling ties directly into the living and dining rooms, which have the original 1/2" ceiling sheetrock panels.
The 1/2" in the other areas is not sagging?
To everyone else... what about installing 2x4's as blocking perpendicular to the existing 24" OC trusses? That would give more spots for drywall screws to bite, but wouldn't require lowering the ceiling...
It seems like with two people, a chop saw and a rented framing nailer you would be able to go through that in a few hours... or does it somehow weaken/damage the trusses?
packer_rich 04-16-2012 08:50 AM
In my area 1/2" is the norm. 5/8" is used in the garage ceiling, garage wall adjacent to the house and above the furnace. My 1972 home is 1/2" on the ceiling throughout, trusses 24" O.C. That being said, if the mold tough is not rated for 24" O.C., don't use it. I've been using the ultra-light and like it. Good luck and be careful.
