Hanging Blueboard On Warped Studs - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-01-2010, 06:11 PM   #1
hanging blueboard on warped studs
Are there any measures that can be taken to hang blueboard on studs that are warped? Such as placing shims behind the wall, etc. Not sure if this is an accepted practice. The warped stud that I would have ot deal with is on a corner (if that makes any difference).
Tonglebeak is offline   Reply With Quote
Old 04-01-2010, 06:30 PM   #2
if its bowed out plane it down, if bowed in add a straight stud to the side
The older I get the better I was
Old 04-01-2010, 06:47 PM   #3
Can the other side of it be shimmed (for bowing out)?
I just replaced the stud, but am wondering in case I need it for a future fyi. Thanks.
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 01:25 PM
hanging upper cabinets without studs picsaro Carpentry 8 04-02-2010 09:28 AM
Cripple studs below a header mercy Building & Construction 3 01-20-2010 03:20 PM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 01:03 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 04:16 PM
