Hang The Top Piece Of Drywall First - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-18-2008, 10:18 AM   #1
Rewards Points: 81
Hang the top piece of drywall first
Can anyone tell me why you should hang the top piece of drywall before you hang the bottom piece?
daxinarian is offline   Reply With Quote
Old 07-18-2008, 10:40 AM   #2
Registered User
Termite's Avatar
If you hang the walls first, you would have a hard time getting the gap for the top piece to sit in right. Your nailers for the ceiling would have to be wider. The wall sheetrock also helps retain the ceiling sheetrock's edges.
Hanging the walls first will also make it much harder to cut the ceiling sheets unless the room is perfectly square, which many rooms are not.
Old 07-18-2008, 10:43 AM   #3
Rewards Points: 81
I was asking about walls. Ceiling before walls I am fine with.
I am asking why do you hang sheet rock on walls starting with the sheet touching the ceiling?
Old 07-18-2008, 10:50 AM   #4
Registered User
Termite's Avatar
Ah, ok!
I always hang the top first because you can get a nice tight joint with the ceiling, and ensure that the sheet is square to the ceiling without having to scribe it in. Then I hang the lower sheet (or sheet plus some) tight to the upper one.
Any gap at the floor will be concealed by the base boards.
Old 07-18-2008, 04:19 PM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
Old 07-18-2008, 04:35 PM   #6
Rewards Points: 81
thanks for the explanation. I hate not knowing the "why" behind the rule
Old 07-18-2008, 07:19 PM   #7
Rewards Points: 6,652
Always go from the Top Down (Ceiling, Top Wall Panel, then Bottom.
Old 07-20-2008, 07:13 AM   #8
HomeAdditionPlus.com
Rewards Points: 29
Because the top piece can butt up nice and tight to the ceiling, where as a gap at the bottom is less important. Baseboard trim will hide the gap at the bottom of the wall. http://www.schluter.com/6_1_ditra.aspx
Last edited by Ron The Plumber; 07-20-2008 at 03:25 PM. Reason: Link in Signature not allowed, please remove it.
mjdonovan is offline   Reply With Quote
Old 07-20-2008, 08:15 AM   #9
Whatamess
If you are hanging more then 6 or 8 pieces rent a drywall jack life will be great.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 07-21-2008, 06:27 PM   #10
besides all that above... dats da way its always bin done.
Big Bob is offline   Reply With Quote
Old 07-22-2008, 05:17 PM   #11
Drywall contractor
Rewards Points: 1,070
Exception to the rule is on vaulted rooms. Start at the bottom. The straight run on the bottom gives you a way to measure the wall/ceiling angle when you get to the top.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 07-22-2008, 05:55 PM   #12
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Same principle applies to stair wells (start at the bottom, and stack upwards).
- Build Well -
Old 07-22-2008, 06:40 PM   #13
Drywall contractor
Sorry to disagree WB. I always start at the top for stairs. Be sure to take at least 6" off the first sheet so a joint does not break where the bottom plate/ floor joists / top plate for the next floor all come together. (Often something doesn't quite line up and makes for a bad joint.) If you start at the bottom, you're starting off with an angle that would be, at the least, time consuming to determine. The stair stringers have a 2"x4" between them and the wall running at the same angle as the stringer (a spacer for drywall and skirt board) fastened to the wall. No way to stack the rock off the floor. I've done it "top down" for 30+ years. It could be done, but not likely by a "production" drywall hanger.
Old 07-22-2008, 06:47 PM   #14
When we do stair wells (without the 2x4s attached to the stringers and wall - this is probably the key point), we place strapping to prop the first sheet section up, cut also to overlay the floor joists (as you stated, to avoid the ugly seam), then stack from there. We use a level to make sure that the first sheet is level. The stacking allows exact measurements for the angle. We do both sides, then install the ceiling last.
We use the T-square, placed upside down, on the lower sheet to find the 4' point, where the angle starts (for the next sheet). That is marked on the lower sheet (installed level). The measurement is taken from that mark to the end inside-angle-end of the lower sheet. This way, the cut angle comes out exact to a fraction of an inch's-fraction. Very-very quick, extremely accurate measuring, perfect angles, and the sheets support their own weight until screwed off.
The difference in the approach, that we are discussing, appears to be with the particular stair construction (I'm referring to stairs without 2x4's attached to the stringer/walls...slide-throughs).
- Build Well -
Old 07-23-2008, 08:46 AM   #15
Drywall contractor
I kinda thought that might be the case. Now it would make sense, and I would agree with your method. Either the 4' square to find the angle or a scrap (14" or so) piece of rock with a factory edge. Done it both ways.
Tags
drywall
Cost to Drywall hang/finish...please read, good explanation Firehawk734 Remodeling 64 12-12-2014 05:15 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
how do you hang drywall 20+ feet in the air? johnny331 Drywall & Plaster 8 07-22-2008 10:06 PM
Best way to hang drywall? 737Pilot Drywall & Plaster 15 07-20-2008 09:06 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
