Hang Drywall Ceiling? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-12-2010, 01:08 PM   #1
dubinpainting's Avatar
I have a Calcamine problem and want to go over existing ceilings with 3/8 drywall how do I do this????
Thanks,
D
dubinpainting is offline   Reply With Quote
Old 11-12-2010, 04:34 PM   #2
Wow, no one can help me with this one?
Old 11-12-2010, 05:53 PM   #3
DIY staff
Rewards Points: 7,174
Find and snap lines,on the existing ceiling, where the joists are---
measure and cut your sheet and screw it to the joists using 1 3/4" drywall screws---
Add drywall adhesive if you use 3/8 I suggest using 1/2" no glue needed with 1/2"
Use a drywall lift if you don"t have a helper.
What is a calcimine problem?
Old 11-12-2010, 06:08 PM   #4
it is possible to fix the calcimine problem, although it may be more trouble than its worth....
http://www.plaster-wall-ceiling-solu...calcimine.html
1910NE is offline   Reply With Quote
Old 11-13-2010, 05:35 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 614
Easier to hang the drywall as Mike instructed. If it really is calcimine, it is a real b*^ch to remove.
Old 11-13-2010, 06:36 AM   #6
Thanks....
Calcamine was a chalk based paint they used in the 19th century to paint over ceilings. It was efective to cover up soot stains from burning coal all winter to stay warm. Most H.O would do it in the spring, kind of like a spring cleaning project. You can't paint over it because the paint won't adhere to the chaulk. It will crack, peel, chip and fail.
Old 11-13-2010, 06:37 AM   #7
Thanks.....
We already treated the ceiling in the enrty-way by scraping and wahing.
The dining room is too big and the H.O wants us to rock over it.
Old 11-14-2010, 05:39 AM   #8
Have you considered running resilient channel (rc channel) perpendicular to the joists and then affixing the drywall perpendicular to the rc channel?
You don't loose much ceiling height and will level off quite nicely where there may be any waves in the ceiling.
williamwiens is offline   Reply With Quote
The Following User Says Thank You to williamwiens For This Useful Post:
oh'mike (11-14-2010)
drywall basement ceiling Dgggless Drywall & Plaster 3 11-14-2010 09:43 PM
Hanging Drywall to a finished Ceiling, Seam Questions? Worker-B Drywall & Plaster 5 08-24-2009 09:40 AM
Ceiling drywall thickness shtoink Drywall & Plaster 11 01-01-2009 07:05 PM
Plaster Ceiling and drywall dprasan Remodeling 6 02-05-2008 11:34 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
