#1 |
Hairline crack in 1950 plaster ceiling comes back
Almost all the ceilings in my 1950 ranch have a hairline crack somewhere. Usually in the center of the room. My father-in-law patched the cracks in two rooms. We primed and painted and the cracks came back after about 1 month.
The ceilings are smooth plaster. The first layer is a drywall like material that comes in rectangular sheets. Then on top of that is a layer of essentially concrete and then a thin layer of white substance that is incredibly smooth. His procedure for patching the cracks (as best I can tell) was to open the cracks. paint cracks with killz2 primer, fill cracks with joint compound, sand, joint compound, sand, joint compound. prime ceiling, paint. On one of the ceilings he used tape, not sure if mesh or paper. Also not sure what point the tape hit the ceiling. Either way, both ceilings cracked. The one with tape looks worse because the tape stands out more than the hairline crack. So my question is, what did we do wrong? We have 3 more ceilings to tackle and 3 chances to do better. I am not going back to fix the two ceilings any time soon, more important things to do. Also, separate issue. There was some water damage to a section of ceiling, likely due to ice dams. I picked out the loose material and now there is about a 4" hole in the ceiling. Should I patch with drywall? I have several 5" cut outs from the recessed lights I put in. I could make the 4" hole a 5" and use one of my cut outs? If you need pictures I will try to get some this week. |
#2 |
I don't have a reply but I did patch cracks recently similar to what you did on my 1922 home. I'm interested to see what others reply in case my issue comes back like yours did.
#3 |
Moderator
Center of the room ceiling cracks may be structural from your built-up beam (3 individual joists) below the center wall shrinking in size due to the climate change; pp.51; http://books.google.com/books?id=iwS...joists&f=false
Paper tape with setting---- not drying-type compound: http://www.usg.com/rc/technical-arti...ems-en-PM5.pdf http://www.plaster-wall-ceiling-solu...wall-tape.html Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#4 |
Push up on them and see if they move at all. If they do you need more screws.
Those panels are hard as a hores heart. I predrill with a masonry bit and use ceramic coated decking screws to pull it in back in place. |
| The Following User Says Thank You to joecaption For This Useful Post: | ltd (11-21-2012) |
#5 | |
paper hanger and painter
Hairline crack in 1950 plaster ceiling comes backQuote:
spell check
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#6 |
Exwifes last name was Hores, it's spelled right.
#7 |
gravity always wins
Hairline crack in 1950 plaster ceiling comes back |
| Display Modes | |
| Plaster ceiling with peeling paint | annaem | Painting | 14 | 01-19-2012 01:10 PM |
| replacing plaster ceiling bathroom | peace | Building & Construction | 3 | 11-27-2011 09:06 AM |
| Coffering Ceiling to Hold Up Falling Plaster??? | Johanne | Drywall & Plaster | 3 | 10-28-2011 05:35 PM |
| Repairing drywall seam after mesh showing hairline crack | Genec | Drywall & Plaster | 7 | 07-20-2009 10:17 PM |
| Plaster ceiling and drywall | desrtrat | Drywall & Plaster | 13 | 10-08-2008 08:20 AM |
