Hair Line Cracks In Drywall Corners - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-29-2013, 01:45 PM   #1
Hair line cracks in drywall corners
I am doing a basement Reno and have reached the mud and taping stage, I have done the first and second coat of mud on and have let it dry for 24 hrs, I am now seeing hair line cracks in the corners. Is this normal if not. What can I do to fix it. I used paper tape i the corners
Rambo1982 is offline   Reply With Quote
Old 04-29-2013, 06:09 PM   #2
Rewards Points: 512
it is not normal.
im guessing its cracked along the edge of the paper in the corners. and this is caused by the paper tape not bonding with the drywall.
what type of mud did you use to set the tape?
you'll have to lift the paper up and apply mud in behind then skim it out.
if its really bad and all over i'd be pulling the paper and redoing it.
princelake is offline   Reply With Quote
Old 04-29-2013, 08:02 PM   #3
Thanks for your reply. The cracks are directly in corner not along the edge of the tape. I used synko taping compound and synko filling and topping compound for the second coat.
Old 04-29-2013, 08:31 PM   #4
Rewards Points: 5,974
I'm not familiar with that compound. Sometimes if you apply the mud to thick it will crack like that. Or if you put fans or a heat source on it to dry it quicker it will crack.
Old 04-29-2013, 08:33 PM   #5
If it's right in the corner, it's likely that you put the mud on thick and it just shrank and cracked a little bit as it dried.
dyne is offline   Reply With Quote
Old 04-29-2013, 09:43 PM   #6
Rewards Points: 1,456
I would guess it shrank as it dried. Wait until it's fully dried and fill the cracks.
mikegp is offline   Reply With Quote
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 03:10 PM
Question Regarding Drywall Cracks Phreek Drywall & Plaster 5 07-26-2012 09:58 AM
Repairing old drywall inside corners before painting? Uncoiler Drywall & Plaster 7 07-08-2012 12:18 AM
recommend a book nvr2low Drywall & Plaster 9 12-21-2011 11:37 PM
Corners with drywall? Ol' Luke Building & Construction 9 11-09-2006 06:17 AM
