-   -   Guidance on surface prep after wallpaper removal (http://www.diychatroom.com/f101/guidance-surface-prep-after-wallpaper-removal-146098/)
jd3030 06-05-2012 03:08 PM
Hey everyone. This is my first post on DIY Chatroom.
I'm looking for some guidance on how to prep the surface of plaster walls after stripping the wallpaper. I just moved into a place that I'm renting. Two rooms (1 large/1 small) have old textured wallpaper which is peeling at the seems (see picture).
http://s17.postimage.org/ia2xp17az/IMAG1350.jpg
I want to strip and paint both rooms at a minimal cost. I have approval from the landlord.
I started with the smaller room to gauge the difficulty level. The wall paper peeled off VERY easily and, for the most part, in entire sheets :thumbup:. There were a few spots of residual glue/backing which I washed down and scraped off no problem.
Now, there a several dings, nicks, uneven surfaces, and a few cracks in the plaster.
http://s8.postimage.org/5ylftg501/IMAG1359.jpg
My first thought was to skim coat the entire room, prime, then 2 coats of paint. Based on the picture, is this all necessary? A couple questions on this approach:
  1. Should I use all purpose compound, topping compound, a blend of compound and something else?
  2. How many coats is really needed?
  3. Should I seal/prime will with something like Guardz? I live in Canada and Guardz is not sold anywhere. Are other Zinsser product comparable (Bulls Eye 1-2-3, Bin)??
  4. If so, does the sealer go on before or after the skim coat.
I appreciate any advise or comments. I would really like to keep the work to a minimum as this is only a rental property.
JD
chrisn 06-05-2012 05:40 PM
1 Attachment(s)
I would prime with Gardz,( do you have Sherwin Williams up there? if so they have a similar product called drywall conditioner)
Just skim the dings etcetra, no need to do the whole room, sand, clean, prime, paint.
