-   -   "greenboard" vs regular drywall (http://www.diychatroom.com/f101/greenboard-vs-regular-drywall-154817/)
texancowboy 08-25-2012 02:08 PM
Hey guys, as I have been trying to re do my bathroom. Yesterday I was told that I need to use something called "greenboard" on all the wall (even NON-shower) area. Is this good advice? Or would using regular be just as good?
joecaption 08-25-2012 02:27 PM
Depends on local codes, there going to at least ask for green board as a min. Some codes call for paperless.
What are you going to use to cover the walls in the shower of bath area?
texancowboy 08-25-2012 03:17 PM
I live where there are very few local codes. Didnt know there was paperless sheetrock. Weird...
As for the shower... probably hardie board and tile
joecaption 08-25-2012 03:24 PM
Code or not it's the right way to do it.
texancowboy 08-25-2012 03:59 PM
all i needed to know
Gary in WA 08-27-2012 01:51 AM
You are under the 2003 IBC; http://www.reedconstructiondata.com/...g-codes/texas/
I personally would not use it, nor does your State code require it; http://publicecodes.cyberregs.com/ic..._25_sec009.htm
Gary:
oh'mike 08-27-2012 06:17 AM
Standard drywall is fine---paint it properly.
stoner529 08-27-2012 09:32 AM
in the event that the texas cowboy is still reading the thread, i will not simply say yes or no but tell you the reason for it.
Green board is more moisture resistant than regular drywall. It has a wic rating in which it takes a certain amount of time for water to soak up through the board and how far it goes. In the event you have a bad leak in the bathroom, they green board will never hurt anything. Its not that much more expensive than regular board. for a shower area. i recommend using either cement backerboard or denseglass. denseglass has a great wic rating which is like only an 1/8 of an inch in an hour opposed to cememt backer or durarock which is like 8" in an hour. you make the call You can research this stuff from their websites as they all have specs on the materials they produce.
scottktmrider 08-27-2012 06:53 PM
I allways use water board in entire bathroom if nothing else for moisture like from the shower.
Most codes say you only have to use it where theres direct water.
bjbatlanta 08-29-2012 03:06 PM
Regular board is fine (and cheaper) with proper paint. The greenboard of years ago had a core that was impregnated with (I'm guessing) some type of "oil based" product and it was much better than regular board for "wet" areas. The core of the board was actually a tan/brown color. I have hung many showers/tubs with it as tile backer. It often failed after time. Mainly because the hangers would set the board right down on the lip of the tub. Once the caulk around the tub failed (or even a leak around a faucet), water would "wick" into the board and it deteriorated. Everyone was under the opinion that this was "waterproof" drywall. It wasn't. That's why concrete type board is now used. The greenboard you get now has the same (white) core as regular board. Only the face paper is moisture "resistant". There are a lot of different opinions out there about this, but I haven't bought a piece of greenboard in at least 20 years. I have had a few customers in a commercial application request the "paperless" mold resistant type of board, but that's where they are expecting some type of water "intrusion" at some point.....
